03-20-2017, 12:58 PM | #1 |
RCC Addict Join Date: Sep 2015 Location: Southern Maine
| Pit bull growlers. Alien compound, worth it?
Hey guys. I'm getting close to being done with my 1.55" full leaf spring custom ascender build. I've got a set of brand new growlers I bough second hand and iim not sure of compound. Willing to bet they're the comp compound and not alien. I'm also not running bead locks so once they're glued, they're glued. Just wondering how to tell what compound I've already got, and if it's worth the money for a complete set of alien compound ones when I've got a new set sitting on my bench. Also, I'd like input from guys running 1.55" growlers on how you like them, what foams you're running and weight of rig. I run mostly bare rock. Mix of smooth and jagged natural ledge face rock. The truck is geared slow but should have some wheel speed as I'm running 4s power with Holmes hobbies crawlmaster motor. Thanks! Ben |
03-20-2017, 01:45 PM | #2 |
Moderator Join Date: Jan 2004 Location: chicago
| Re: Pit bull growlers. Alien compound, worth it?
i wont give foam advice but the comp compound tires are very good and get better once you get a little wear into them. i wouldnt hesitate to run them.
03-20-2017, 01:49 PM | #3 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
If they don't have the alien puppy on the sidewalk then they're the older comp compound. The old compound is still great, and has performed REALLY well for many years. I personally ran some cut down 1.9 Rock Beast foams in my Growlers for years. Crawler Innovations also has some great foams, and he can point you in the right direction if you know the weight of your rig and it's intended purpose. Just don't glue them up on the inside of the rim until you get the foams figured out.
03-20-2017, 04:49 PM | #4 |
Quarry Creeper Join Date: Dec 2015 Location: Norway
I'm interessefelt in the same thing. Is there any of you that's tested both compounds in the 1.55 Growler? An comparsion would be great. |
03-21-2017, 06:33 AM | #5 |
Rock Crawler Join Date: Jan 2012 Location: middle TN
I have not got to run these yet, as I'm still building. But here you can see the alien puppy as mentioned above. I will be running the foams supplied with these tires. They are softer than deuces wild foams but firmer than Lil novas. I think they will work well on my heavier hard body cherokee with curries. |
03-21-2017, 07:16 AM | #6 |
Growlers are great on some surfaces, but not so good on others. If you have clean, dry rocks you'll love them. If you mud, loose dirt, or wet rocks you're not going to be a big fan.
03-21-2017, 07:35 AM | #7 |
Thanks. I don't do mud, period. Mostly dry natural rock and hard packed trails. Sometimes at the beach the rock is wet from the surf but at that point. No tire is really good on slimy algae covered beack rock. Mostly wondering if the alien compound is THAT much better for me to warrant buying a set insead of using my brand new set in komp compound. Thanks! Ben |
03-21-2017, 07:43 AM | #8 | |
| Re: Pit bull growlers. Alien compound, worth it? Quote:
03-21-2017, 07:49 AM | #9 |
The original growlers work great. A friend runs them on his class 1 tf2. Honestly his seem to work good on the wet Creek beds also. I'm hoping the alien compound is even better.
03-21-2017, 07:53 AM | #10 |
Once the komp compound tires are broken in, they should be good for the intended purpose. Komp compound gets better as the tires wear more but alien compound gives you that same broken in performance straight out of the bag for immediate gratification (obviously the new compound will get better as it wears too but I'm not yet sure how much better). Unless you are in a hurry to extract maximum performance, use the tires you have and drive them as much as possible.
03-21-2017, 02:33 PM | #11 |
Newbie Join Date: Jan 2014 Location: Little Elm
They all preform well, but the Alien Compound is awesome! Sent from my SM-N920V using Tapatalk |
03-21-2017, 05:33 PM | #12 |
Quarry Creeper Join Date: Nov 2011 Location: In the woods
I have used the 2.2 Alien growlers for an entire summer. The more the tires wear, the better. The only tire I have used when it's wet it performs as good as it does dry. I highly recommend them.
03-21-2017, 10:51 PM | #13 | |
RCC Addict Join Date: Jun 2009 Location: Australia
I also ran 1.9 Rock Beast foams in my 1.55 PB Growlers in comp conpound and they filled the tyre nicely . They have been the goto tyre for a long time and even by other drivers of other brands. Many RC4WD drivers run them too. That alone should tell you how good they are as a goto tyre. As others said the more you run them the better they get. Sent from my SM-G930F using Tapatalk Last edited by Oz Bruiser; 03-21-2017 at 10:53 PM. | |
03-21-2017, 11:28 PM | #14 |
Rock Crawler Join Date: Apr 2009 Location: bend
I have the 1.9's and 2.2's and they work great. Like everyone has said the longer you run them the better they perform.
03-22-2017, 02:45 AM | #15 |
Thanks guys. I have a set of 1.9" rock beasts with the ci rock beast foams. Single stage and LOVE them. The foams are amazing with the tires. How are you guys running 1.9 foams in 1.55 tires? More specific, are you running 1.55 tires stretched on 1.9 rims with 1.9 foams? Or doing something to the foams or rims to take up the space since the run is 1.55" and the inner circle of the foam is 1.9". I'm running 1.55" rims with these 1.55" Growlers. Thanks! Ben |
Pit bull growlers. Alien compound, worth it? - Similar Threads | ||||
Pit Bull PBX A/T Hardcore Alien compound review and video | new2rocks | Tires and Wheels | 10 | 05-18-2016 07:13 PM |
Pitbull 2.2 Growlers in alien compound | SoCal Crawlr | Axial Yeti | 4 | 05-16-2015 11:46 PM |
Alien Technology 2.2 Pit Bull Growler | dezmoon | Tires and Wheels | 38 | 05-02-2015 10:57 AM |
