05-27-2018, 01:33 PM | #1 |
Rock Crawler Join Date: May 2018 Location: USA
| PL Hyrax stock foams or CI foams?
I was looking into getting new foams that are better for crawling but Im not sure what to do. Proline sells a crawler foam, and crawler innovations seems to be the big name in the game. Are my hyrax tires going to perform markedly better with CI foams or the crawler PL foams? Is it marginal? Should I spend the 26$ on something else for crawlability? |
05-27-2018, 01:35 PM | #2 |
Rock Crawler Join Date: Nov 2014 Location: Dells
| Re: PL Hyrax stock foams or CI foams?
They will perform the same.
05-27-2018, 01:37 PM | #3 |
| Re: PL Hyrax stock foams or CI foams? |
05-27-2018, 01:43 PM | #4 |
I'm talking about the dual stage prolines vs dual stage CI foams. Not sure what you're thinking of...
05-27-2018, 03:02 PM | #5 |
Rock Crawler Join Date: Dec 2009 Location: Suffolk
He's talking about WRT the stock foams that come with the tires I think.
05-27-2018, 04:24 PM | #6 |
05-27-2018, 04:58 PM | #7 |
Rock Stacker Join Date: Apr 2017 Location: CT
In my experience if you ask 10 people about tire/foam choice, you will get 10 different responses. That’s not a bad thing, but it’s enough to make your head spin. There are other things to take into account like truck weight, terrain, and how you drive it, and or what you expect it to perform like. Being fairly new to crawling I asked the advice of a long time user of the same brand/model rig I own. They recommended single stage closed cell foams either CI or the newer blue Prolines. So that’s what I’ve been running on my two Ascenders, and I really like them. Most people when they squeeze my tires, all say they feel stiff. But it’s been working for me and how I use them. In the end, IMO I think your best to do what I did and ask someone who has the same rig as you, or just experiment for yourself. I have yet to use any foams that came with tires I’ve bought, that’s not to say they may or may not work just fine.
05-27-2018, 05:14 PM | #8 |
ProLine foams for ProLine tires. CI for everything else.
05-27-2018, 07:34 PM | #9 |
05-27-2018, 09:50 PM | #10 |
Yeah, thats basically what I am asking.
05-27-2018, 09:51 PM | #11 |
Also if there are any that are fully waterproof, as in not damaged by water, that would be a big plus as where I run a lot is rocks on the coast of a lake.
05-27-2018, 09:55 PM | #12 |
I have the Proline Hyrax with the Proline Dual stage foams. (1.9 and the 2.2 versions) They fit and work well together.
05-27-2018, 09:56 PM | #13 |
05-27-2018, 10:15 PM | #14 |
05-27-2018, 10:21 PM | #15 |
05-27-2018, 11:27 PM | #16 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
CI's single stage inserts are waterproof (closed cell foam)... but also stiffer and meant for higher speed stuff.
05-28-2018, 12:28 AM | #17 |
Im curious how long the pro line foams run with semi regularly seeing water.
05-28-2018, 12:39 AM | #18 |
05-29-2018, 08:10 AM | #19 |
I am running the hyrax tires on my almost 15lb wraith its running the stock foams i feel they are to soft for my rig i was running closed cell.foams in the old tires and i realy liked them i wish they fit in the hyrax but they dont and i havent found any more material to make new ones and cant realy aford new foams my old tires worked alot better with closed cell.foams i would imagine the hyrax would.work better with stiffer foams also my biggest issues are when climbing up hill on steep rocks and sidehilling also turning at speed the foams role over i feel the closed.cell foams would help alot on my rig but my rig is very heavy a lighter rig would be totaly differant
05-29-2018, 08:51 AM | #20 | |
| Re: PL Hyrax stock foams or CI foams? Quote:
PL Hyrax stock foams or CI foams? - Similar Threads | ||||
What CI foams for hyrax? | Mikeinsocal | Axial RR10 Bomber | 30 | 10-05-2017 09:53 AM |
What pair of foams to replace the stock bomber foams? | nd4spdbh | Axial RR10 Bomber | 14 | 10-11-2016 10:36 AM |
Stock HB Rover Foams or Proline Memory Foams? | norco kid | Tires and Wheels | 3 | 10-13-2012 11:00 AM |
Stock AX10 foams or Losi Rock Claw foams? | ForkliftJeff | Axial AX-10 Scorpion | 1 | 04-06-2008 10:28 PM |
