04-08-2020, 12:07 PM | #1 |
Rock Crawler Join Date: Aug 2010 Location: Salt Lake
| Tire/Foam recommendations needed. Mounting issues.
I'm just getting back into crawlers after nearly 10 years. I have a brand new SCX10 2 Honcho. I bought a three piece internal beadlock steelie set and I'm having difficulty mounting the Pro-Line flat irons I have. The inner ring of the steel wheel seems too small for the inner lip of the tire. They are both 1.9 in size. I've mounted tires on RC4wd wagon wheels before and they were difficult but manageable. Is it an issue with the flat iron tires? Would another tire work better? Thanks for any help in advance.
04-08-2020, 12:21 PM | #2 | |
Rock Stacker Join Date: Jan 2020 Location: US
| Re: Tire/Foam recommendations needed. Mounting issues. Quote:
04-08-2020, 12:27 PM | #3 | |
https://store.rc4wd.com/19-Proline-T...gs_p_2878.html Last edited by lonleycreeper; 04-08-2020 at 12:29 PM. | |
04-09-2020, 12:36 PM | #4 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
Internal beadlocks can be a pain, especially with the thick bead of Proline tires. Its even worse if you're using the ginormous foams that come stock with their tires. You might be able to get it done simply by using a couple longer screws to start off, then switching to the shorter ones once you have the bead seated. If you do not have screws long enough, an extra set of hands might be what you need. One to squeeze the wheel halves while the other screws them down. Trimming the inner edge of the foams a little bit is another trick that might be helpful.
04-09-2020, 01:42 PM | #5 |
Quarry Creeper Join Date: Aug 2009 Location: orange county
Wd40 on the beads or some kind of lube. Don’t put them together dry. You will be cursing for days.
Tire/Foam recommendations needed. Mounting issues. - Similar Threads | ||||
Tire Foam Recommendations for Gen 8 | hotrod6107 | Redcat Crawlers | 20 | 05-12-2020 07:48 PM |
Tire and Foam recommendations for HEAVY TRX-4 Defender Rig | marketability | Tires and Wheels | 2 | 11-26-2019 08:23 AM |
2.2 TSL XL Foam Recommendations | 864runner | Tires and Wheels | 9 | 04-16-2016 07:41 AM |
foam recommendations... | hatefulboy | Axial Wraith | 2 | 08-07-2013 06:02 PM |
foam recommendations | YYCADM | Tires and Wheels | 0 | 09-02-2011 09:10 PM |
