Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Can You Re-Glue Tires?
Old 05-23-2020, 08:05 PM   #1
Default Can You Re-Glue Tires?
Today I bought a Like New 2012 SCX10 C/R Edition Jeep Wrangler. This truck is basically New Old Stock as the Woman that bought it drove it “ Gently” a couple times. All original with Box, Spare Parts Bag, Manual etc.
The Foams in the tires are almost Nonexistent! I’d like to know if it’s possible to remove the factory Axial KRAWLER tires, install a decent foam, and re-glue them back on the factory wheels? I have numerous other sets of wheel/tire combos I could throw on it, but I’d like to keep it as close to stock as possible as it’s truly completely stock at the moment.
jwag1973 is offline   Reply With Quote
Old 05-23-2020, 08:46 PM   #2
Default Re: Can You Re-Glue Tires?
Yes. Just as CA glue is used to adhere tires, there is CA remover you can use to remove the glue. There are other ways, but, if not done properly, they can damage the tire and/or wheel. Just replace the foams with ones of your choice, and reglue the tires.
~ More peace, love, laughter & kindness would make the world a MUCH better place
Panther6834 is offline   Reply With Quote
Old 05-23-2020, 10:04 PM   #3
Thanks, I’ll check into that and give it a try.
Old 05-25-2020, 09:23 AM   #4
Put the tires in a sealed container of Acetone for a day or two. It will melt or at least soften the CA glue and release the tire from the rim. Then clean it off, dry it, install new foams and re-glue.
PeteN95 is offline   Reply With Quote
Old 05-25-2020, 09:45 AM   #5
NOT a good idea. Acetone can dissolve certain plastics, and it can eat through various rubber compounds.
Old 05-25-2020, 06:56 PM   #6
Agree with Panther. I've had acetone ruin a wheel not too long ago, so recommend not using it.
dungeonracer is offline   Reply With Quote
Old 05-26-2020, 02:16 PM   #7
I'm kind of new to this myself but isn’t there a method where you heat the tires/rims up to a moderate temperature to remove them?
OnTheTrail is offline   Reply With Quote
Old 05-26-2020, 04:32 PM   #8
Originally Posted by OnTheTrail View Post
I'm kind of new to this myself but it's there a method where you heat the tires/rims up to a moderate temperature to remove them?
You could try that...tho, you might melt something.
Old 05-26-2020, 10:08 PM   #9
CODYBOY's Avatar
I've been successful removing tires from plastic wheels in the oven.
I put four tires and wheels in pre-heated oven at 350 for 20-30 minutes. I put them on a sheet of tin foil, fold it over the tires and put them in the oven. I don't know if I should say "don't try this at home", but it worked for me!
Ernie
CODYBOY is offline   Reply With Quote
Old 05-26-2020, 10:15 PM   #10
ive had good luck leaving them in the sun for a few hours then peal the tire off
ferp420 is offline   Reply With Quote
Old 05-27-2020, 08:58 AM   #11
This is how I have been removing mine for sometime now. Removing Glued Tires from Rims - Gramps Ramblings
Gramps is offline   Reply With Quote
Old 05-27-2020, 02:24 PM   #12
Moderator
JatoTheRipper's Avatar
That's a pretty cool site you have there! Very well organized.
Old 05-27-2020, 07:24 PM   #13
Doubt I’d want to try it in a kitchen range but I have a cheap food dehydrator that I can set to reasonably low temps. May give that a try some time on the stock TRX wheels/tires. I can increase the temps slowly till the glue loosens up.
Can You Re-Glue Tires? - Similar Threads
What do you guys use to glue tires other than CA glue? country_crawler Tires and Wheels 38 03-17-2015 11:10 PM
To glue or not to glue...rear tires Snipervision Losi Mini-Rock Crawler 3 12-24-2010 11:01 AM
CA Glue for tires Savrunner Newbie General 7 02-01-2007 10:38 AM
Best Way To Glue Tires? MGS511 Tires and Wheels 7 09-14-2006 09:38 AM
