04-28-2023, 06:43 PM | #1 |
Rock Stacker Join Date: Mar 2023 Location: Mass
| TRX-4 wheels rounded out
I bought a set of Proline wheels for my TRX and the hubs on the wheels have rounded completely out. I wasn't paying attention when I ordered them and didn't realize they were a one piece plastic beadlock. What does everyone recommend for a replacement that won't brake on me in the future. the tires on them are still pretty good but the Wheel hubs themselves are done. I am not looking to spend a ton of money as I am waiting for a very special wheel to be finished by Lockeduprc. But in the meantime I would like to order a decent cheaper beadlock.
04-28-2023, 06:51 PM | #2 |
Pebble Pounder Join Date: Oct 2020 Location: Pittsburghish
| Re: TRX-4 wheels rounded out
For spending a small amount of money for good quality name brand wheels, I'd recommend GMade SR02 (or similar). I have a set on my TRX4 and they add a bit of weight down low and fit nicely. For a bit more, SSD beadlocks have been fantastic. |
04-28-2023, 08:32 PM | #3 |
| Re: TRX-4 wheels rounded out I will look into those thank you.
04-29-2023, 10:47 AM | #4 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
SSD steel wheels are inexpensive and durable. That's all I use. I've never had a problem. Sent from my SM-G991U using Tapatalk |
04-29-2023, 12:04 PM | #5 |
Rock Stacker Join Date: Mar 2020 Location: Bay area
I second the SSD stamped wheels. Or grab a cheap set of aluminum china beadlocks on Amazon. Sent from my LM-G900TM using Tapatalk |
04-29-2023, 03:21 PM | #6 |
beadlock wheels are dirt cheap from china another option is to mod the wheels you have to run a slw style hub Last edited by ferp420; 04-29-2023 at 03:33 PM. |
04-30-2023, 07:57 AM | #7 |
| Re: TRX-4 wheels rounded out |
04-30-2023, 08:25 AM | #8 | |
| Re: TRX-4 wheels rounded out Quote:
drill hole out "i think its 8mm but thats just off the top of my head " place the slw hub against the wheel place the lip on the slw inside the hole then using a red hot paperclip to mark the 6 mounting holes then drill out the holes and there ya go ive also used clod buster hub adaptors and drilled them out and bolted them to the rims | |
04-30-2023, 11:06 AM | #9 |
After purchasing the SLW hubs and the hardware, this wouldn't really be any cheaper than the gmades (or the Amazon beadlocks), would it? Sincere question. Unless it's meaningfully cheaper, I'd rather have wheels that weren't sort of cobbled together. |
04-30-2023, 11:28 AM | #10 |
there about $10 and you dont have to unglue your tires ofcourse new ones are always better but if you want to squeze some more life out of those wheels you most likly could but for $10 more you can get aluminum beadlocks |
04-30-2023, 11:52 AM | #11 |
| Re: TRX-4 wheels rounded out That's not too bad - I was seeing them for 17-20 for a pair, plus hardware. If they're available that cheaply... |
04-30-2023, 12:32 PM | #12 | |
US $3.99 30%OFF | INJORA CNC Aluminum 12mm Wheel Hex Hub for 1/10 RC Crawler Car 1.9 2.2 Wheels Rim Axial SCX10 Capra Redcat Gen8 VS4-10 https://a.aliexpress.com/_mOXtPKk | |
04-30-2023, 12:35 PM | #13 |
04-30-2023, 12:35 PM | #14 |
There's also this thread that has been stickied long ago: Drill press rim mod's with VP hubs Also, you can buy certain plastic wheels like these Element bronze ones: https://www.amainhobbies.com/element...c42100/p977615 And upgrade the hubs to aluminum or brass: https://www.amainhobbies.com/element...c42103/p977617 https://www.amainhobbies.com/element...c42104/p977618 And even add wheel weights that look like brake discs: https://www.amainhobbies.com/ssd-rc-...00379/p1147111 The end result with some SSD scale hardware: Of course, there are definitely some very reasonably priced aluminum beadlocks to be found on sites such as Amazon - where I scored these HobbySoul models: https://www.amazon.com/HOBBYSOUL-Bea...13&sr=8-6&th=1 Last edited by durok; 04-30-2023 at 01:02 PM. |
TRX-4 wheels rounded out - Similar Threads | ||||
So my screw is rounded out | Frank211 | Tools, and Procedures | 19 | 05-08-2022 01:17 AM |
Removal of rounded set screw? | Crutch | Tools, and Procedures | 13 | 04-09-2015 10:32 PM |
Rounded wheel hubs | optikalillushun | Newbie General | 3 | 11-30-2012 03:25 PM |
Anyone else with rounded wheel hex hubs? | Maxx_Savage | Venom Creeper | 14 | 09-22-2010 02:27 PM |
help with rounded off screws.. | mudhunter | Tools, and Procedures | 12 | 12-01-2006 07:39 PM |
