Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: is brazing the same as soldering?
Old 02-12-2008, 09:44 PM   #1
Default is brazing the same as soldering?
like is says, is brazing the same as soldering. would the solder work? cause i have hundreds of dollars worth of solder. just wondering if that would work.
punkafi888 is offline   Reply With Quote
Old 02-12-2008, 09:49 PM   #2
Dirt Addict
roktoy's Avatar
Location: Stumblin' thru the parking lot of an invisible 7-Eleven
No....soldering uses softer materials that generally melt at lower temps and are not as strong as brazing materials.
Soldering will work if you want to work with brass tubing, but brass is relatively weak and heavy.
Jay
roktoy is offline   Reply With Quote
Old 02-16-2008, 12:42 PM   #3
Silver solder such as safety silv 45 works very good. Plumbing type solder, see roktoy's answer.
DumpsterRC is offline   Reply With Quote
Old 02-16-2008, 04:04 PM   #4
06 Super National Champ
JasonInAugusta's Avatar
Brazing and soldering are, in effect, the same thing - just at different temps.
In both processes you're joining two items through capillary action with a filler metal when you braze or solder.
Brazing requires higher temps than soldering and is done with a filler that usually has a higher tensile strength than "solder".
You can reheat a brazed or soldered joint and the two pieces can be removed from one another.
JasonInAugusta is offline   Reply With Quote
Old 02-16-2008, 04:26 PM   #5
thankyou this helped very much i have been soldering for maybe 10 years now and am a pro. does lowes or any other place like that have the brazing rods i have looked and cant find any.
Old 02-16-2008, 07:19 PM   #6
solder is way too soft for frame structures. brazing and soldering are basicly the same from a process standpoint. But a good rule of thumb is higher the melting temp = stronger weld joints. this only applies in brazing/soldering.
TK-twister is offline   Reply With Quote
Old 02-16-2008, 07:28 PM   #7
Go to a welding supply shop and get Harris Saftey-Silv. It comes in a roll like solder and should run $10-12/oz.
There are NO weld joints when soldering or brazing.
Welding actually fuses the two parts together with a filler to form one piece.
