07-25-2005, 08:48 PM | #21 |
Rock Crawler Join Date: Apr 2004 Location: Longmont, CO
Comparing my HF metal saw to my dads Sears Wood cutting bandsaw I'd say a big disadvantage would be the squareness of cut... Most of the time cutting metal your cutting about 1" thick... with wood the material is on average thicker so the angle is more important. Also the blades are deeper, so doing curvey cutts are harder It is slower like you say, I cut wood with mine but it's never for anything important. |
09-13-2005, 03:00 AM | #22 |
Rock Stacker Join Date: Jun 2004
yer the one thing i cant stress enough is to use alluminium wax when cutting alluminium it can really fawk the blade quickly with no wax im not sure why it does this what ive been told is the alluminium just bonds its self to the blade and clogs it up
09-19-2005, 12:22 PM | #24 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
I broke out my 9" Ryobi last weekend to go some chopping on my TXT frame and make up some susp links (Fishmaxx, you can get the Ryobi blades ((I think 56 1/2")) at Lowes). Picked up a new 18tpi blade and went to work. Sliced through the aluminum frame like butter. It was nice to use a rip fence so that you can make the identical cuts on both pieces. Then made the first eight links. Blade went through both the aluminum rod and steel threaded rod with complete ease. Then made of the second eight, aluminum rod went great...........steel rod, not so great. Blade was already dull! A good amount of force was needed to push the rod through, got REAL hot on the way, and messed up the threads on the rods. Thanks Ace for the tip on the wax lube. I'll try some out next time! |
09-19-2005, 12:45 PM | #25 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
09-26-2005, 01:35 PM | #26 |
Quarry Creeper Join Date: Feb 2005 Location: fresno
i like the ellis mier band saw modle # 1600 blade size 10'0" x1" x .035 it helps me a lot in class. but thats my .02$ |
10-03-2005, 03:42 PM | #27 |
Pebble Pounder Join Date: Aug 2005 Location: Rochester
There should be some sort of tracking adjustment to keep the blade centered on the wheels. also it helps to set the guide blocks after setting the tension/tracking-that way it doesn't stress the blade as much. You can get blades of different depths too, back in the studio we had 3TPI blades that were only like 1/4" deep from the tip of the teeth to the back of the blade. You have to get the right blade for your application.
10-15-2005, 10:46 AM | #29 |
As long as the blade length is right for the saw, in this case 14", you should be able to go back and forth from metal to wood blades.
10-16-2005, 07:57 AM | #30 | |
Pebble Pounder Join Date: Oct 2004 Location: Colorado
If you want to purchase a Band saw that could be used for both metal and wood, then you need something like this saw: http://www.amazon.com/exec/obidos/tg...24742?v=glance The important specs are: [SFPM is: Surface Feet Per Minute] • Cutting Speeds Wood (SFPM) 3300 • Cutting Speeds Metal (SFPM) 39, 57, 78, 107, 142, 196, 278 If you want my suggestion, :-P I use separate band saws for metal and wood. I don’t like the idea of contaminating my wood projects with metal filings, oil, cutting wax, etc. I also don’t like cleaning sawdust off my metal cutting band saw and hassle of changing blades with deeper gullets for sawing wood. But, that’s my opinion. Charts: http://www.niagaracutter.com/techinf...eed/chart1.gif http://www.endmill.com/pages/training/spdfeed.htm For most steel cutting applications, the range when using high speed steel cutting tools varies from 30 to 200 surface feet per minute, By comparison, carbide cutting tools when machining steel are generally used in the range of 300 to 500 surface feet per minute. Wood cutting is done at sppeeds of 2000+ SFPM. Any way, here’s a quick guide for Blade Speeds for band saws: (Notice that cutting aluminum at high speeds is Ok) Speed (SF/M) range Material being cut.................................Blade Speed in (SFPM) Structural steel........................................165 Low carbon steel.....................................160-165 Medium carbon steel................................115 High carbon steel.....................................90-100 Cr-moly steel...........................................10 5-135 Ni-Cr-moly steel.......................................90-115 Chromium steel.......................................80-140 Cr-vanadium steel...................................105-115 Tool steel............................................. ....40-80 Stainless steel.........................................40-70 Free machining steel................................80-100 Cast iron.............................................. ....55-90 Copper alloy (CU-Zm)...............................55 Bronze............................................ .........90 Al-bronze............................................ .....40 Monel............................................. ..........40-45 Titanium alloy...........................................25-40 Aluminum (soft).......................................3000 Aluminum (T-6+)......................................3000 Carbon............................................ ........3000 Slate............................................. ...........80-160 PTFE sheet, rod, rounds..........................3000 Hard rubber............................................ .3000 Plywood........................................... ........3000 Other woods............................................3 000 | |
10-16-2005, 11:49 AM | #31 |
Quarry Creeper Join Date: Mar 2004 Location: Central NY
Thanks BultacoJim that's a nice list. I plan on cutting mostly aluminum some plastic, but having the right speed for steel would be nice. THIS one looks like it'd just about provide the speeds you listed. It'll go from 1-2645FPM; that'd let me cut what I want and is cheap enough to get a second if I want one for wood. |
10-18-2005, 07:08 PM | #32 |
Though the speed goes down far enough, it most likely won't have the torque at the lower speeds for cutting much steel. Its better than nothing, but for cutting steel and other hard materials, a bandsaw with a geared speed range is more desireable. unfortunately, they are much more expensive.
10-26-2005, 09:10 AM | #33 |
I bought the second saw I linked along with an 18t blade. What speed should I use for cutting plastic wheels? Also how about tire foams; think it'd work for that?
12-07-2005, 10:21 AM | #34 |
| bought this one
Well I bought this one today, from what I have read on RCC, everyone is pretty happy with this one, we'll see. http://www.harborfreight.com/cpi/cta...emnumber=37151 |
12-07-2005, 11:12 AM | #35 |
Uni, If you find your blade keeps popping off try tightening the tension harder. I babied mine but then I read it's about impossible to overtighten the blade tension just tightening the knob by hand. Since then I tighten almost as tight as I can get it, while the saw is running. It still slips off but very infrequently now. Don't be afraid ta hoss down on the tension! |
12-07-2005, 11:32 AM | #36 | |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
12-07-2005, 06:15 PM | #37 | |
RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
01-06-2006, 11:33 AM | #38 | |
Brand Starrett Blade Length (Feet) 5Ft.4-1/2In. Blade Width .5000", 1/2, 12.70mm Teeth per Inch 18 or 24 Type Flex-Black or Hard-Back Material Carbon Steel or High Carbon Steel My question is which options in red should I choose to cut links and mostly .064 sheet aluminum? Thanks. | |
01-06-2006, 01:23 PM | #39 |
[QUOTE=badger]Hey Ace, I have lost a few teeth on my stock blade and want to order a better one. On that web site there are a few options to choose from. Badger, let me know what you go with, I have the same issue with mine. |
01-07-2006, 11:27 PM | #40 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
I'd suggest looking around and trying to find an old one when someone's clearing a shop out or something. The one in our shop is a 60's Delta, the electrics were a little messed up when we got it, but that was easily fixed, it acctually uses a house style setup, and a light switch for on/off. But it works and cuts beautifuly.
