02-14-2010, 07:39 PM | #1 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
| i want to dye white delrin......
what is the best why to dye white delrin without wrecking it....it is for a skid plate.............bob .... |
02-14-2010, 07:44 PM | #2 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
Go buy RIT Black dye, heat up the dye in a pot of hot water dye mix as per the instructions. take it off the stove and let it cool down just a little bit. drop you Delrin piece in the mixture and it should turn black. Keep repeting this step until you get the desired black you want. Edit, Im an idiot. maybe someone can clarify if this works on delrin. I know it works on the White nylon rims. Thats the process if it works for Delrin |
02-14-2010, 08:19 PM | #3 |
yeah i'v done tons of nylon parts, but not sure bout delrin though.........bob .... |
02-15-2010, 03:36 PM | #4 |
Newbie Join Date: Feb 2010 Location: nc
no delfin isnt porous enough to soak up the dye. it kinda gets a smugy purply coating. thats about it. if you want a diffrent color try some krylon fusion paint, or high temp paint
02-15-2010, 04:14 PM | #5 |
Back when Eritex made his first sets of beadlock wheels I bought a set. They are made of Delrin and are dyed black. I know they are dyed because I drilled breather holes in them and the material is white. Ask Gerame if he remembers how he did it. |
02-15-2010, 04:57 PM | #6 |
Quarry Creeper Join Date: Jul 2008 Location: South Dakota
I'm pretty sure liquid rit dye with some salt in the water will get the job done. I colored some homebrew skis that way a few years ago for my tmaxx.
02-15-2010, 05:20 PM | #8 |
02-15-2010, 05:28 PM | #9 |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
Uraplatys (T1e) did a post in his MRC Rockshow thread on how he did his, located here: Dyeing 101.
02-16-2010, 10:42 AM | #10 |
I dump some powdered dye in some water with a pinch of salt, bring it to a boil, turn the heat down a tad, and drop the parts in. Check it every 5 minutes for color. Once its the color I want, I pull it out, rinse it in cool water, wash it with some soap, and call it good.
02-16-2010, 10:50 AM | #11 |
N.E.R.C.C Uncle Blinky Join Date: Dec 2008 Location: RUKDNME...
1 old pot 1 pack rit die heat the water drop in the die shut off heat drop in your parts and remove from heat. i let my axial 1.9 sit over night came out killer and have dun the same to all the stuff iv'e died. never had a prob with warping or stuff like that it's ez like the old nike add....jist do it GSRCC Drail
02-16-2010, 01:04 PM | #12 |
thx guys fer all the replies and links ...............bob .... |
