06-26-2012, 03:41 PM | #1 |
Pebble Pounder Join Date: Nov 2009 Location: pennsylvania
| braze
so i bought some map gas today and torch would any one be kind enough to post a quick vid of map gas brazing aluminum rod like a how to that works? also i made a bender do you heat the metal( i assume) or just force it(seems not correct :P) going to build one from scratch! |
06-26-2012, 04:21 PM | #2 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
| Re: braze
you dont see ally brazed to often - atleast not on RCs. Im not saying it can not be done, just that I dont think I have seen it on here. And weather you heat the tube to bend it or not is up to you. Without seeing your bender I cant even guess what it is capable of doing.
06-26-2012, 08:15 PM | #3 |
Pebble Pounder Join Date: Aug 2011 Location: Gresham, OR
| Re: braze
Most people use either solid steel rod or brake line. Since you don't have an oxy setup I would suggest using brake line. It will heat up much faster.
06-26-2012, 08:17 PM | #4 |
| Re: braze
MAPP gas will not get hot enough to get aluminum to flow, you need oxy/acetylene to make that happen.
06-27-2012, 04:55 AM | #5 |
| Re: braze
okay then were can i buy straight brake line?
06-27-2012, 05:27 AM | #6 |
| Re: braze
You should be able to find it at most auto parts stores. Some brake line is coated, make sure you get rid of it before brazing, the fumes are toxic. Best if you do a search and read about using brake line.
06-27-2012, 05:32 AM | #7 |
| Re: braze |
06-27-2012, 08:10 AM | #8 |
| Re: braze
lots of help awesome guys, i read a few places that ppl braze aluminum all the time with just mapp? not going against the grain because clearly you guys do this and know what the hell your doing( via some the rigs yous have built) but are they just blowing smoke or leaving out some info
06-27-2012, 11:32 AM | #9 |
| Re: braze
okay so i have mapp, im getting brake line from napa with no coating at 3, and will brazing rods labeled nickel silver work ?
06-27-2012, 07:34 PM | #10 | |
| Re: braze Quote:
06-27-2012, 10:13 PM | #11 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
| Re: braze
napa auto parts has un coated brake line that's where i get all mine at .........bob .... |
06-28-2012, 06:22 AM | #12 |
| Re: braze
I picked some uncoated up yesterday and some brazing rods which they had also!! now time to draw it up on paper and start slowing trying this :P
06-28-2012, 08:02 AM | #13 |
| Re: braze Firepower 1440-0401 - Brazing Rod | O'Reilly Auto Parts thats the brazing rod i got, but when i tried it this morning for one the tube didnt even glow using mapp gas and when one little piece did the rod didnt do anything |
06-28-2012, 08:05 AM | #14 |
| Re: braze
is there another video? the one stickied doesnt work for me
06-28-2012, 08:50 AM | #15 | |
| Re: braze Quote:
06-28-2012, 08:54 AM | #16 |
| Re: braze
The rod in the link says it requires flux, did you get that as well? I couldn't see it well enough to read what material the rod is made from, does it say on the box? If it's copper coated steel you can forget about ever melting it w/ a MAPP bottle, you would need a TIG torch to melt it. I doubt that you would even be able to get brass rod to flow w/ your MAPP bottle. You will need to use some Safty-silv type of rod, somewhere between 30-50% silver content to get any strength from the joint.
06-28-2012, 09:00 AM | #17 |
| Re: braze
alright so what can i buy at a decent price from lowes, home depot? one of those places even an ace that would work? they dont have harris that i know of
06-28-2012, 07:17 PM | #18 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
| Re: braze |
06-28-2012, 07:44 PM | #19 |
Rock Crawler Join Date: Mar 2011 Location: hampton
| Re: braze
i use 1/8th" coated lincoln electric brazing rod. mapp will do it with the right torch head. i use this crosstech head. its expensive but works great Crosstech Double Torch Head with Clean Out TM2100CLO | eBay |
06-29-2012, 02:38 PM | #20 |
| Re: braze you probably WON'T find what you need at a home improvement store. Look in the yellow pages and find a welding supply company near your house, they will have EVERYTHING that you need. You may even find the stuff at a commercial plumbing supply house, a lot of HVAC repairman use brazing equipment to make their repairs. |
braze - Similar Threads | ||||
how do i braze? | NEW YORK BOY | Tools, and Procedures | 16 | 06-25-2010 09:25 AM |
braze? | crawlinnTN | Tools, and Procedures | 2 | 03-31-2010 12:09 AM |
braze brakeline to..... | mudrinner4ever | Tools, and Procedures | 7 | 11-28-2007 12:35 PM |
HOW TO: Braze | cabsover78 | General Crawlers | 1 | 07-19-2007 08:49 PM |
How do you braze? | Bronco Fetish | Tools, and Procedures | 38 | 10-31-2006 12:49 PM |
