07-03-2012, 10:55 PM | #41 | |
| Re: Eyeball Engineering Quote:
We've got a trip planned soon to go see my folks, and my dad and I already have a little adventure scheduled for a visit to the Yard Store. If any of you happen to be in or around Wichita Ks, you have to check this place out. They buy all the surplus stuff from the local aircraft plants. All kinds of cool stuff. In the past we've spent a couple of hours just looking around, and they have new stuff you didn't see the last time you were in, so its like a mini treasure hunt. Anyway, I'm hoping to pick up some stuff for the mill while I'm there. The really sucky thing? About 10 years ago my dad retired from Beechcraft, and machining was one of his trades (he had a few!). At some point he had pointed to a big machinists toolbox and asked me if I wanted any or all of it. I gave it a quick look-over and said "nah, I'll never need any of that". Dumbass. | |
07-03-2012, 10:59 PM | #42 |
| Re: Eyeball Engineering |
07-04-2012, 07:10 AM | #43 | |
| Re: Eyeball Engineering Quote: | |
07-04-2012, 07:29 AM | #44 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
[QUOTE=Duuuuuuuude;3807724] The name plates just made me feel like I was back in school, making dumb things to hand off to my family at Christmas time. I made a letter opener out of 1/4" aluminum in shop class for my mom...she used it every day. When she died a few years back I found it going thru her stuff...I have it now. I don't think she thought it was dumb.... Nice mill ....thanks for the visual, helps me understand some of the terms you guys use. Would love to have one to try out, but it just seems a bit over my skill level. Certainly doesn't look like the $100 special at Hobby King though. I'm sure that others don't look like that either. Guess I'll search and see what I can find for comparison....Any of you other mill owners care to share a pic of yours? |
07-04-2012, 08:08 AM | #45 | |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
Yeah it looks goood and stout. Man chris that story about your daddy and his tools is like 'dejavue from when my uncle Gene did the same thing to me, the kid with other crap on his mind . He was a machinist at Kaiser steel before they went banckrupt and then worked for years at Griffin wheel, (they made train wheels) , fortunately years later my cousin called me out to his garage on a visit and said, "looky here , I have some of dad's stuff left, do you wnat it"? HELL YA I DO. Some of this stuff is hand made tools and other very old Starrett last word instrurments. I've heard about that salvage yard in KC, I may have to make that part of our trip back that way when we go see our grandkids. Quote:
07-04-2012, 09:06 AM | #46 | |||
What amp breaker? What sized wire? So you know, 12ga wire can handle 20A, 14ga wire can handle 15A. The breaker rating is to protect the wiring, so if you have 12ga wiring and a 15A breaker, up the breaker rating. Quote:
As to your T-nuts, I would make them thicker than the steel ones. Aluminum is not as strong. Rule of thumb is: Soft material (plastic, brass, aluminum, etc) needs 2 diameters thread engagement at a minimum. Hard material needs 1 diameter thread engagement at a minimum. Thus, a 3/8" diameter thread/bolt needs 3/4" minimum engagement. A little more is better, 4x as much is past needed. As to your trigger, nice. I agree, you would be better if you left the inner corner of the brake with a radius. This could be done by milling the shape from the side with a ~3/8 mill, it would leave a 3/16" radius. Better stress area. You could almost mill the side shape off the end of a long block, then cut it off and belt sand the side tapers. Hope that makes sense. Quote:
As to "Industrial Arts", I wish my son could go through it. Way back when, I had: Wood Shop Metals Electrical Electronics Printing (with individual type......) Small engines Automotive (1.5 years) Oh, Duuuude, you should also mess with regular milling (?) and climb milling. I preferred climb milling for aluminum & plastic, it tended to leave less crap on the finished surface. Each has a use. | |||
07-04-2012, 09:32 AM | #47 | |||
Enco or Grizzly would be places to look for one similar to mine, or try Tiny Machine Shop for a tabletop unit. Quote:
20a breaker, no clue what ga wire is in the walls, I'll run 12 for the new outlet. Quote:
Done that. Interesting the difference a direction will make. | |||
07-04-2012, 01:16 PM | #48 |
Quarry Creeper Join Date: Jul 2004 Location: Arkie-Saw
I'm not sure how much slop your ball screws have, but be careful climb milling. Stupid kid at work I was trying to teach this stuff to didn't care to listen and got some sweet stitches in his arm. He went the wrong way on a sloppy machine, 3/4" end mill grabbed that 1/2" plate he was putting a chamfer on and pulled it right out from under the toe clamp. Didn't help that he wasn't tightening the clamp well but still...shit happens. What cut him was the chip that stayed attached to the part as it went flying to the ground, which he just made taking way too big of a cut way too fast. Lesson learned. Needless to say he doesn't help me anymore.
07-04-2012, 02:12 PM | #49 |
Not a lot of slop, but enough to notice it if I try to take a big bite. I was told to make sure I move the table in accordance to the way I will be cutting so that it can't shove it over, or just tighten down the screws if I'm making a single pass.
07-04-2012, 03:13 PM | #50 |
Made some soft jaws out of grey pvc. Man that stuff is nice to work with. Probably will add a vertical and horizontal channel to hold round stuff. |
07-10-2012, 10:29 PM | #51 |
Finally got an edge finder and a test indicator. Hooray for new tools. More goofing off. Don't ask, I don't know what it is either, just something I thought I'd try. |
07-10-2012, 11:07 PM | #52 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
That pretty cool |
07-10-2012, 11:25 PM | #53 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
Can you make me a thingamajig? I keep wanting one but no one knows what it is. I told them it connects to a whatchamadohicki Jeesh and we have professionals here |
07-11-2012, 06:55 AM | #54 |
07-11-2012, 05:43 PM | #55 |
I wanna be Dave Join Date: May 2006 Location: akron
07-11-2012, 06:44 PM | #56 |
get someone to suck the doomaflachy out of it and you get a widjit in no time...can you get that as an attachement ???
07-11-2012, 07:38 PM | #57 | |
RCC Addict Join Date: Oct 2009 Location: San Francisco
Thought of getting 6" Loc-Line 1/4" Flexible Modular Pipe Sump/Return | eBay and LOC-LINE 1/4" 1/16"DIA HOLE ROUND NOZZLE NEW!!! | eBay and LOC-LINE 1/4" NPT CONNECTOR PACK OF 4 COOLANT HOSE FOR LATHE OR MILL | eBay and make a simple "air blaster" for when your cutting. 1/16" nozzles are nice since you can make them bigger if need be and it gives a nice directed flow of air just a thought to save end mills | |
07-11-2012, 08:09 PM | #58 | |
The air blaster I currently have is a box fan I'm using to keep the biggest tool in the shop cool. Me. | |
07-11-2012, 08:46 PM | #59 | |
Quarry Creeper Join Date: Oct 2008 Location: Oakley
[QUOTE=Postclanker;3808045] Quote:
Just thought I would share.... 10 tool changer, full 3-axis I do make a lot of "stuff" .. I had 2-axis machines years ago, this one makes many things possible... | |
07-11-2012, 09:33 PM | #60 |
| Re: Eyeball Engineering LOL! Just a thought, it could easily be attached to the machine or a mag base... its amazing what a difference just a lil stream of air makes when cutting stuff |
Eyeball Engineering - Similar Threads | ||||
rocksmith engineering | D-Ride | Newbie General | 14 | 05-19-2012 11:40 PM |
Engineering Question | BJoe | Chit Chat | 14 | 03-04-2008 01:15 PM |
