11-24-2013, 02:02 PM | #1 |
I wanna be Dave Join Date: May 2010 Location: The east coast
| 3mm in 3/16 brake line: suggestions??
I need to mount some 3mm bolts (or set screws) in some brake lines. Has to be pretty sturdy and has to be 3mm. Since I can't just thread thread in the bolt (like I would with a 4mm) I need a different way. Things I have considered are: 1. Braze in a long set screw of bolt (cut the head off) and use a nut. I'm worried I won't get the screw soldered in solid enough given the small space between the screw and tubing wall may not allow for enough solder flow. 2. JB weld in a set screw or bolt. I haven't used this before so I'm not sure about the strength. 3. ??? I'm doing this to hook revo rodends to a snowplow mount so it needs to be able to handle some serious shocks, like when I slam the blade into a crack in my driveway! |
11-24-2013, 02:52 PM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: 3mm in 3/16 brake line: suggestions??
JB weld is super strong!!
11-24-2013, 03:52 PM | #3 |
| Re: 3mm in 3/16 brake line: suggestions?? |
11-24-2013, 04:06 PM | #4 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
why not a steel tube you can thread into?...If you already have a tap and the all thread or bolts to cut for it just get a tube...Can get one for probably the cost of a tube of JB weld and it be much much stronger.
11-24-2013, 04:33 PM | #5 |
| Re: 3mm in 3/16 brake line: suggestions?? Not a bad idea but too late for that. I already have the frame made up with brake tubing. Not something I want to start over on. Good idea for the next project.
11-24-2013, 05:09 PM | #6 |
| Re: 3mm in 3/16 brake line: suggestions?? Good idea! But that stuff sticks pretty well without help. I learned this the hard way, when I did something very stupid with the stuff.
11-24-2013, 09:21 PM | #7 |
I've silver soldered M3 nuts to the ends of tubes before. Thread the nut onto an M3 bolt, and slide the bolt into the tube. The bolt holds the nut in place, and keeps it square to the end of the tube. If you are careful, you should not have a problem with the bolt being soldered into place.
11-28-2013, 09:21 AM | #8 |
Quarry Creeper Join Date: Nov 2006 Location: Manchester
If you're using revo ends isn't a 3mm too small? If 3mm is what you want what about using a flanged 3mm nut? |
11-28-2013, 01:17 PM | #9 |
| Re: 3mm in 3/16 brake line: suggestions?? The ball uses a 3mm, which is what I needed to mount to the brake line. In the end I decided to give the JB weld a try. Worst case it doesn't work and I try something else.
11-29-2013, 08:21 AM | #10 |
Oh I was thinking for the shank. My bad.
12-01-2013, 04:37 PM | #11 |
Newbie Join Date: Jun 2013 Location: otown
for 3/16 brake line I use 6 32 screws and a 6 32 tap, fits pretty good.
12-01-2013, 08:24 PM | #12 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
I have threaded 4mm in 3/16" brake line....
3mm in 3/16 brake line: suggestions?? - Similar Threads | ||||
Brake line | slash23 | General Scale Talk | 17 | 11-02-2013 12:35 AM |
brake line | oscodawave | Newbie General | 15 | 10-09-2010 11:58 PM |
Brake line! | warfile | Tools, and Procedures | 34 | 08-26-2009 03:48 AM |
brake line ? | nodnarb81 | Tools, and Procedures | 2 | 01-30-2008 10:47 AM |
How much Brake line? | run2jeepn | Newbie General | 1 | 05-30-2006 04:32 PM |
