01-19-2015, 09:47 PM | #1 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
| soldering temperature question
I got tired of my junk and bought a TK-950 soldering station. I have been on you tube for hours and still have 1 question. How do I know how much heat or tip temperature I need? I am just doing stuff like bullet connectors esc and battery connectors. Do I just set it to kill or what? My old junk was non adjustable so this is all new to me.
01-20-2015, 05:03 AM | #2 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
| Re: soldering temperature question
I run my Hakko at 750 on the dial, then adjust it from there if needed....
01-20-2015, 10:38 AM | #3 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
| Re: soldering temperature question How to solder correctly (a not so brief lesson) - R/C Tech Forums excellent thread
01-20-2015, 02:16 PM | #4 |
Newbie Join Date: Feb 2011 Location: Beaverton
I use a 800 degree tip in my old school weller station if I am soldering esc wires. But for bullets and other connectors I use my 700 tip. Be sure to keep the tip clean and tinned. |
01-20-2015, 03:34 PM | #5 |
Newbie Join Date: Jan 2014 Location: New London
I have the same tk-950 setup and i like to solder around the 800 range. Def a killer solder station. Usually doing the bullet conectors ill crank it all the way to max heat to make it easier. But to much heat for a long period of time can make the joint brittle. Practice makes perfect good luck.
01-20-2015, 09:19 PM | #6 |
THANKS everyone for the help. Time to practice and get it done.
01-21-2015, 12:06 PM | #7 |
I generally solder at 700*...If you have a good station, you don't need a higher temperature for a bigger joint. Your station should start spewing out heat to the iron to maintain the set temperature. Old school, you use a big tip and higher heat for soldering big stuff because the station wasn't capable of quick thermal recovery. But modern stations can really pump out the heat, so a standard size tip and normal temperatures work just fine. Also, get a flux pen, makes your life alot easier if you flux everything before soldering, The one sitting on my desk is a kester #186 flux-pen.... |
soldering temperature question - Similar Threads | ||||
Soldering question | Bogncrawl | Tools, and Procedures | 7 | 05-14-2013 09:22 PM |
Temperature guidelines for soldering | cpercival | Electronics | 6 | 07-25-2012 02:51 PM |
silver soldering question | sliceofnoob | Tools, and Procedures | 20 | 04-09-2012 09:11 PM |
Soldering Iron Question | Drey | Electronics | 41 | 05-30-2010 11:57 PM |
Soldering Station Question | jbrentd | Electronics | 9 | 09-07-2008 07:44 PM |
