Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Airbrush compressor
Old 01-21-2017, 04:51 PM   #1
Default Airbrush compressor
Looking to get into using an airbrush, I have a 60 gallon shop compressor out in the garage, should I get an air dryer and regulator and use that or should I look for a small dedicated airbrush compressor? What are the pro's and con's of using both? I figure it will cost about the same to either set up my big compressor or to by a decent airbrush compressor. Thoughts and opinions appreciated!
sled is offline   Reply With Quote
Old 01-21-2017, 05:15 PM   #2
Default Re: Airbrush compressor
Buy a cheap regulator with built in water separator($15). You don't need anything special. It's nice if the regulator is easy to access when painting.
whitrzac is offline   Reply With Quote
Airbrush compressor - Similar Threads
Airbrush and compressor questions zjguy721 Paint and Body 2 03-28-2014 01:41 PM
Airbrush compressor advice JohnB Paint and Body 1 01-23-2014 06:01 AM
airbrush and compressor, any opinions on these? LDogg Paint and Body 4 02-17-2010 01:38 PM
air compressor for airbrush brandontodd33 Paint and Body 2 06-02-2009 12:21 PM
