03-15-2017, 02:18 PM | #1 |
Quarry Creeper Join Date: Dec 2016 Location: DA U.P.
| Shock Grippers
Was looking at 4 different shock shaft grippers. Any thoughts? Grid RC Shock Shaft Tool for $19- Uses screws to clamp instead of hand grip. RDRP Gripper $29- Looks like a high quality piece. Team Losi Shock Shaft Pliers $25. Nice size handle and might not need as much force. ProTek Shock Tool $25. Also has pillow ball tool along with shock body holder, but looks a little small and hard to use. Right now I'm leaning towards the Losi or Grid RC.... |
03-15-2017, 02:22 PM | #2 |
| Re: Shock Grippers
I have the ProTek and I'm a big fan. I like the it has the tool to help install and remove hollow/pivot balls. The Grid RC one will be a pain to use. The Losi one does shock shafts and that's it. |
03-15-2017, 04:45 PM | #3 |
| Re: Shock Grippers
Good analysis Jato, I also bought the ProTek after looking at quite a few.
03-15-2017, 05:10 PM | #4 |
| Re: Shock Grippers
Yeah the protek is bitchin titties.
03-15-2017, 06:09 PM | #5 |
| Re: Shock Grippers
Those Protek shock pliers are some of the best money I have ever spent in RC.
03-15-2017, 09:48 PM | #6 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Shock Grippers
I like the tekno one, has everything you need. Edit: part number TKR1115. The 4mm shock shaft part works good for holding links while threading rod ends on. Last edited by 84yoda; 03-15-2017 at 09:52 PM. |
03-15-2017, 10:12 PM | #7 |
| Re: Shock Grippers
Paper towel and a pair of pliers or needle nose? Worked perfect all my life.
03-15-2017, 10:44 PM | #8 |
| Re: Shock Grippers |
03-16-2017, 04:39 AM | #9 |
Quarry Creeper Join Date: Jun 2011 Location: butler pa
| Re: Shock Grippers
yeah racing makes a nice pair also
03-16-2017, 06:52 AM | #10 | |
| Re: Shock Grippers Quote:
Why do things the ghetto way when you can get the right tool that will last a lifetime for $25? | |
03-16-2017, 07:42 AM | #11 | |
With a little 5min worth of searching you can find Tekno's for $.50 more than ProTeks. Having owned my first Tekno RC and using various parts from them on other builds I agree that Tekno product is more expensive than a comparable product. With a little research some items are not or at all more expensive. I can say from experience that in the case of Tekno it is definitely justified. https://www.hobbies4life.com/tekno-p...product/145101 | |
03-16-2017, 07:45 AM | #12 |
| Re: Shock Grippers
I've done the paper towel thing for 30 years and it always makes me cringe a little....never knew they made these. I ended up grabbing the Tamiya one as it had all the features as the Protek but was a few bucks cheaper and also had a ballcap holder. Should make changing out pistons a lot easier at the track. Getting back into onroad and going to try out the new TAO7 kit. |
03-16-2017, 07:55 AM | #13 | ||
03-16-2017, 12:14 PM | #14 |
03-16-2017, 01:20 PM | #15 |
03-21-2017, 11:18 PM | #16 |
RCC Addict Join Date: Jun 2004 Location: ORegon
| Re: Shock Grippers
If you have to use paper towels or electrical tape you are doing it wrong. And personally, I don't like unitaskers (tools that only do one thing) unless it is the only way to really do the job right and efficiently. I never see myself owning any sort of shock shaft pliers or clamp at any point in the future. What do I do then? Wire cutters. Everyone should have a pair in the tool box and no additional materials are needed to use. Grip the shock shaft right above the threads. The sharp edge grips surprisingly well. Thread the shock end on. The gripped area is low enough that it should never come in contact with the o-rings in the shock. I rarely even notice any marring anyway. Some shocks even have flat spots at the end of the shaft. I still use wire cutters for these since needle nose pliers will scratch much more area (just making it look ugly) than the thin edge of the wire cutters. If you are a tool junkie, buy the shock shaft tool. If you are a minimalist and value efficiency but still want to do the job right, try your wire cutters. If you don't have some already... well, that is a tool you should buy.
03-22-2017, 07:26 AM | #17 |
03-22-2017, 08:13 PM | #18 | |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
Seriously though, having worked with tools almost my whole life and having wasted more money than I hate to think about by using cheap or the wrong tools, I now try to take advantage of the things people manufacture to make the job as easy and painless as possible. I realize there are probably as many opinions about this as there are members here. Just my thoughts. | |
04-01-2017, 01:59 PM | #19 |
Quarry Creeper Join Date: Jan 2016 Location: Southampton
| Re: Shock Grippers
A good set of shock pliers are worth the $$$. In a pinch I would put a piece of rubber tubing on the jaws of my needle nose pliers. I am a tool whore though |
04-02-2017, 02:55 AM | #20 |
Quarry Creeper Join Date: Jun 2004 Location: Melbourne Australia
| Re: Shock Grippers
Don't be a pack of girls Just long nosed pliers just above the shock threads works a treat, ya not ever going to compress them that far to damage the orings |
Shock Grippers - Similar Threads | ||||
Any reviews on rc4wd fuel mud grippers? | XJrob | Tires and Wheels | 12 | 05-20-2016 10:08 PM |
Shock & spring advice for GCM shock hoops. | Ca. Off Roader | Vaterra Twin Hammers | 11 | 01-04-2016 12:17 PM |
Timmy Tenscale's Product Showcase with ZNO-RC "Godfather Grippers - Tire Chains" | ZNO-RC | General Scale Talk | 2 | 05-31-2012 12:11 PM |
Axial shock pistons in big bore shock bodies | Kanine38 | Newbie General | 2 | 03-11-2010 06:47 AM |
