![]() | #21 |
Quarry Creeper Join Date: Dec 2013 Location: Lancaster
I'm really not convinced so far that the 2.2 ripsaws are better than the 1.9 ripsaws I also have. I believe that they are both r35 compound. Has anyone else noticed the 1.9ripsaws seeming softer than the 2.2s? I wonder if the foams are too stiff, or if there is too much foam stuffed in the tire. Does anyone know if the hpi soft foams are large enough to work here, or of they would be an improvement at all over the stock axial foams? Perhaps I just need to get more weight on them to deform them more. |
![]() | #22 |
Can anyone recommend me a 1/10 scale, 2000kv or so, sealed and sensored motor? I have a gforce 2250 kV sensored motor which is great, but being 1/8 scale with summer temps approaching, I'm afraid it'll push the mmp too hard. So I'd like to find a 1/10 scale motor that is similar in specs. |
![]() | #23 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
I've been eyeing a sensorless airplane outrunner for mine eventually.
![]() | #24 |
Why a sensorless outrunner? Do they run smoother than a sensored inrunner? I have plenty of sensorless in runners, just don't want the cogging.
![]() | #25 |
Rock Crawler Join Date: May 2012 Location: Central PA
Sensorless won't be as smooth as a sensored motor no matter what style it is.
![]() | #26 |
I'm aware of that. I guess a better question to ask is, why an outrunner over a standard inrunner?
![]() | #27 |
| ![]() I would also be interested in that. My shop I work out just has the standard brushless motors but the other place I check out has both styles as they sell tons of planes and have both styles in stock. I might as my buddy and see what he says. If I find out anything I will let you know.
![]() | #28 |
I *think* they just come in lower kvs. Without coating an arm and a leg.
![]() | #29 |
Yup, low kV, high torque, I've been thinking of one that is the equivalent of a .15 airplane engine since it is similar in size to a 540 motor with the same bolt spacing, can use a 5mm pinion, is reasonably priced when compared to a high end brushed crawler motor and even moreso vs a sensored BL motor.
![]() | #30 |
Most low kV inrunners are very large, and very expensive, so that makes a lot of sense. Keep us updated! What size would we need? ![]() Last edited by mwe-maxxowner; 04-21-2015 at 09:28 AM. |
![]() | #31 |
I was looking at this one in particular. Power 15 Brushless Outrunner Motor, 950Kv | HorizonHobby I had thought about sticking one on my SCX10, but since the Telluride's tub chassis would help keep debris out of the thing, it would be a better application. Last edited by BJoe; 04-21-2015 at 09:34 AM. |
![]() | #32 |
Ahh dangit it isn't sealed! Mine will see water.
![]() | #33 |
I'm not worried about water so much as I am grasses, weeds, and especially fishing line (fawking fishermen that can't clean up after themselves ![]() Last edited by BJoe; 04-21-2015 at 07:25 PM. |
![]() | #34 |
I drive through very muddy and pebbley water with mine. If it was fresh mountain spring water maybe not so much. Hqhq
![]() | #35 |
I put a set of wheel extenders on my telly to fit a set of sweet aluminum 2.2 beadlocks I bought used. They add 17mm,and are the smallest ones I could find. Most common was +25mm. Lol. I don't need 17 whole mm. Anyone know of options that don't widen me so much, that fit over a 5mm axle, use the proper sized axle pin, or a set screw, and are for a 12mm hex?
My take on a Telluride Trail Truck | John82601 | Traxxas Crawlers | 60 | 02-02-2016 11:03 AM |
New traxxas telluride 4x4 | crawlernut | General Crawlers | 31 | 12-15-2013 03:47 PM |
Traxxas Telluride FoFF....:) | Laker67 | Formula Offroad | 0 | 12-03-2013 01:14 PM |
Traxxas telluride | azwheelman | Videos! | 18 | 10-03-2013 09:17 AM |
Traxxas Telluride | zjguy721 | General Crawlers | 4 | 09-06-2013 12:07 PM |
