01-06-2018, 10:58 AM | #1 |
Newbie Join Date: Nov 2017 Location: Zebulon
| Suggestions for tires
I have finally received my trx4. I run mostly in the woods (North Carolina) collecting rocks from farm fields around my property. I plan on getting some gmade steelies or China beadlocks for a second set to run in the creeks and mud. I may just leave them on... Looking for suggestions on a good tire for trail use...woods, logs, roots. I have read about the foam and I am confused (noob) about single stage or duel stage. What is best for mostly trail use? From many of the posts it looks like proline is the way to go, but I am a bit confused what to select.. Thanks for any help. |
01-06-2018, 11:59 AM | #2 |
Quarry Creeper Join Date: Nov 2016 Location: Switzerland
| Re: Suggestions for tires
I use Mad Beast with matching CI single stage foams. I am very happy with them but in the end, the possibilities are almost endless. Just get tires you like most between 113 mm to max 120 mm and go for it. If you want a very soft foam go for dual stage if you like a bit firmer foam or your rig is very heavy take a single stage foam. Look around in this section and you will find many topics around tires and foams. |
01-06-2018, 12:32 PM | #3 |
Pebble Pounder Join Date: Jul 2016 Location: Ne pa
For a stock trx4 steel or aluminum wheels with proline hyrax tires and crawler innovations 2 stage mediun foams and about 6 oz of weight behind grill and go have fun!
01-06-2018, 02:57 PM | #4 |
Newbie Join Date: Aug 2017 Location: Fort Carson
I really like the Proline BFG Krawlers, although I do not have a lot of experience in the hobby. I find they are good all around trail/crawling tires. https://www.prolineracing.com/tires/...n-truck-tires/ |
01-06-2018, 03:15 PM | #5 |
Newbie Join Date: Jan 2016 Location: Escondido
I just put some Proline Flatiron xl’s with Locked Up Rc bead locks on my trx4. I went with Proline dual stage foams as well. I took it out crawling this morning and was very pleased with them. Sent from my iPhone using Tapatalk Last edited by Bronco RC Crawler; 01-15-2018 at 06:05 PM. |
01-08-2018, 10:28 AM | #6 |
Thanks guys! I like all of them. I think I am leaning to the hyrax.
01-08-2018, 12:16 PM | #7 |
RCC Addict Join Date: Nov 2010 Location: England
Lot of good feedback about the RC4WD Goodyear MTR's in the wheel tire section. I just ordered the 4.19" for my Ascender as I drive in wet/muddy terrain, probably similar to you. My other has Duratrax Deep Woods which are 4.75" and work great.
01-08-2018, 05:03 PM | #8 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
Keep the stock tires they're great and clear quickly, just plug the 2 holes on the inside of each rim to keep the water out!
01-09-2018, 02:53 AM | #9 |
RCC Addict Join Date: Feb 2012 Location: UK
I find even the stock tires rub the front of the body shell when turning under some flex. I think 4.6' tires are too big and that is stock! I have some heavily warn Baja Claws that do the same. If they were new there would be a lot more rubbing. :-)
01-09-2018, 07:42 AM | #10 |
Quarry Creeper Join Date: Oct 2006 Location: Great White North!
Hyrax hands down!
01-09-2018, 10:27 AM | #11 |
Hyrax or TSL Super Swampers. Best all around trail tires out there.
01-09-2018, 11:37 AM | #12 |
RCC Addict Join Date: Jun 2016 Location: Germany
I use hyrax on SSD Rock racers very pleased with the performance. Just a little Body trimming to eliminate rubbing. Send by my Pixel 2 XL with Tapatalk Last edited by magic_yeti; 01-09-2018 at 12:05 PM. |
01-09-2018, 11:40 AM | #13 |
Pebble Pounder Join Date: Apr 2007 Location: shadyside
believe it or not, iam running old school proline hammers, 2.2 on ssd steel beadlocks, amazing tires for sure, wished they still made them
01-23-2018, 02:47 PM | #14 |
I think I like the super swampers look.
01-23-2018, 07:03 PM | #15 |
Pebble Pounder Join Date: Sep 2009 Location: Airdrie, Alberta
I haven't bought tires yet either. I'm leaning toward the hyrax or Rock Beast xl. I hear that the Rock Beast xl are sticky, but hyrax seems to be getting the best reviews from people.
01-23-2018, 07:10 PM | #16 |
RCC Addict Join Date: Sep 2017 Location: The OC
Hyrax = PB RB Pick yer poison. |
01-23-2018, 07:45 PM | #17 |
I have a set of 1.9 Pit Bull Alien Growlers mounted on 2.2 Vanquish Method 105 wheels with CI two stage foams and have found them to be a good all around tire. I also have a set of 1.9 Pit Bull Rock Beast tires mounted on another set of the same wheels. Here is my #1 TRX4. Last edited by Inspector86; 01-23-2018 at 07:50 PM. |
01-24-2018, 12:11 AM | #18 | |
Newbie Join Date: Jan 2018 Location: Camas
| Re: Suggestions for tires Quote:
I use growlers to I totally love them however I kinda wish I bought hyraxes instead Sent from my iPhone using Tapatalk | |
Suggestions for tires - Similar Threads | ||||
Suggestions for a vehicle that can use 95mm tires? | fyrstormer | General Crawlers | 9 | 12-04-2016 09:29 PM |
Suggestions for Wheels/tires/foams and shocks | Adamgllc | Axial RR10 Bomber | 27 | 08-19-2016 10:37 AM |
what 1.9 tires suggestions | airride | Axial SCX-10 | 32 | 04-25-2014 07:50 AM |
Any suggestions balancing tires on my SCX10?? | kodiakman624 | Axial SCX-10 | 12 | 12-09-2009 02:25 PM |
