Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: battery question
Old 07-08-2018, 09:40 PM   #1
Default battery question
What are the dimensions on the battery box on the trx4? Will original traxxas plugs work the newer id plugs? If they don't work, what battery does everyone run in these things?
Dezertdirt is offline   Reply With Quote
Old 07-08-2018, 10:31 PM   #2
It’s big enough for a 7 cell flat nimh pack, & it works with any Traxxas connectors. There’s also a space for a small lipo built in to the bottom of the box & another space for a small lipo in front of the steering servo
TUSOffRoad is offline   Reply With Quote
Old 07-09-2018, 12:05 AM   #3
Default Re: battery question
If you buying new batts I’d plan for a LCG battery tray. :-)
o0wiz0o is offline   Reply With Quote
Old 07-09-2018, 09:46 AM   #4
If you replace the battery arm with velcro you can get 2 5500mAh lipos in before it really compromises the balance. The tray itself is more than long enough for any lipo I've seen, probably around 7-8" long. I'll get the actual number when I get home and can look.
Lord_Fabricator is offline   Reply With Quote
battery question - Similar Threads
Battery Question?? BIGMANliltoyz Electronics 5 10-01-2012 06:54 AM
battery / battery charger question EricTheRitt Electronics 4 09-07-2011 07:59 AM
Battery question...yes, I read the battery thread...twice... MikeTJ Losi Micro-Rock Crawler 14 06-07-2011 07:44 PM
Battery Question DakotaH Newbie General 3 12-25-2010 10:38 AM
Battery Question(s)!? coolkidjf7 Electronics 6 09-23-2007 06:42 PM
