Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Aux power with a hobbywing 1080
Old 08-06-2018, 12:50 PM   #1
Default Aux power with a hobbywing 1080
Hi gents, as the title says, I am replacing my stock esc with a hobbywing 1080 so that I can run a JX cls-5830HV 30kg servo.
I have the factory traxxas lighting kit for my head/tail lights and light bar all running off the factory aux power port. How can I power these moving to the hobbywing esc?
Foxtrot121 is offline   Reply With Quote
Old 08-06-2018, 12:56 PM   #2
Default Re: Aux power with a hobbywing 1080
I had to do the same, if you're keeping the XT60 connector, you'll have to do a bit of soldering.
Or use an auxiliary battery just for it.
Sent from my Pixel 2 using Tapatalk
brimdogg is offline   Reply With Quote
Old 08-06-2018, 03:47 PM   #3
Or if you are using the internal bec at 7.4v just re do your wiring and plug it into the programming port on the esc.
redemon is offline   Reply With Quote
Old 08-06-2018, 04:41 PM   #4
That would work if your running a Sport but if you have a Kit, Defender, or Bronco I don't think the diff and shift servos can handle the 7.4V
Cleanest way is to splice in a JST connector onto the ESC side of the battery connection which is essentially what they did on the stock ESC.
If your not comfortable with soldering you could always go with something like this https://www.ebay.com/i/272804672822?chn=ps
You'd just need to double check that the JST end is the correct male/female orientation as I can't remember off the top of my head what orientation the JST coming off the stock ESC is.
Asuckaphish is offline   Reply With Quote
Old 08-06-2018, 06:53 PM   #5
The same (or similar) servos come in the nitro trucks. A fully charged NiMh 5cell hump pack is 6.5-7v. They can handle 7.4v.
ThunderbirdJunkie is offline   Reply With Quote
Old 08-07-2018, 12:55 AM   #6
I made up an xt60 adapter to go between the esc and battery with a jst cable added
Sent from my SM-G920F using Tapatalk
Dave_Pinnock is offline   Reply With Quote
Aux power with a hobbywing 1080 - Similar Threads
Hobbywing 1080 settings Jboucher Electronics 80 04-25-2020 02:48 PM
HobbyWing 1080 settings. Oh How Original Electronics 3 04-04-2018 06:37 AM
Hobbywing 1080 krazee Traxxas TRX-4 2 12-21-2017 09:03 PM
Hobbywing 1080, power button mount local? NitroDarwin Axial RR10 Bomber 11 09-11-2017 07:42 AM
Hobbywing Quickrun 1080 triggerhapy Electronics 0 12-17-2016 01:04 AM
