Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Outside power switch linkage
Old 10-22-2018, 08:00 AM   #1
Default Outside power switch linkage
Tired of taking the body off my TRX-4 to turn the power on and off, I rigged a mechanical linkage to allow me to do it from outside. I'm certainly not the first to do this, but I though I would share my approach.
I started with a Hitec cross servo horn - I have lots lying around.
I cut off one of the arms and shortened the remaining two. I had some 1/16" angle aluminum too, so I cut a bracket from that. It's stiff enough that the servo horn can be supported on only one side. That's done by a 2mm bolt and nylock nut through the bracket and the bottom hole on the downward servo arm; the tension on the servo horn is tight enough to keep it from moving on its own but loose enough to not keep pressure on the ESC power button. The black bands around the forward edge are 3 layers of heat shrink to better engage the power button, which does not protrude much. The brass part on the right is a 2-56 clevis, which passes through the floor.
The aluminum bracket is attached to the floor with 2 bolts and nylock nuts. a 2-56 bolt is screwed into the brass clevis, and that is the external link that turns the power on and off.
The setup works very well.
JD and Beastlet is offline   Reply With Quote
Old 10-22-2018, 08:08 AM   #2
Default Re: Outside power switch linkage
Nice, reminds me of the switch lever I had found and used when I had stock electronics still.
Sent from my Pixel 2 using Tapatalk
brimdogg is offline   Reply With Quote
Old 10-22-2018, 09:30 PM   #3
It's just a good habit to unplug the battery when the truck is not in use.
Inspector86 is offline   Reply With Quote
Old 10-23-2018, 06:55 AM   #4
Moderator
JatoTheRipper's Avatar
It's more than a good habit IMO. It's required. If you do not unplug the battery from your truck you WILL eventually kill a battery.
Old 10-23-2018, 07:50 AM   #5
Yeah when do you unplug the battery when you use this lever?
mebeknob is offline   Reply With Quote
Old 10-23-2018, 08:40 AM   #6
I hadn't though of that though I do remember reading about it in the Traxxas manual. Why is that necessary, and does it apply to NiMh batteries as well?
Old 10-23-2018, 11:34 AM   #7
Leakage current.
Turning the ESC off only shuts down the BEC supply inside the device. There is still an electrical connection across the switch FETs inside the speed controller. FETs are not ideal and not truly "open" when not switching.
Over the course of weeks or months and depending on your battery charge, it will deplete your battery. If your just turning it off when your out crawling, there is no need to disconnect your battery. Assuming a few hours at a time, worst case.
Affects all batteries.
Sent from my HTC U11 using Tapatalk
drzoo2 is offline   Reply With Quote
Old 10-24-2018, 08:48 AM   #8
Originally Posted by drzoo2 View Post
Leakage current.
Thanks for the explanation. The switch will be still be useful during a crawling day but I will remember to disconnect the battery for longer idle periods.
Outside power switch linkage - Similar Threads
Where to Mount Power Switch? nickz1122 Axial SCX-10 12 04-17-2012 04:38 PM
Sub-Atomic Power Switch losikid Vendors Electronics 5 04-01-2012 01:53 AM
Need a power switch...help! Nelstrodomous Electronics 2 06-11-2009 11:15 PM
switch wiring for power, do u switch - or + toy4crawlin Electronics 3 09-09-2008 04:59 AM
power switch problem SlammedMini469 General Crawlers 14 05-13-2006 10:24 PM
