Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Trx4 sport truggy build
Old 12-29-2018, 08:38 AM   #1
Default Trx4 sport truggy build
I CUT THE BED OFF THE SPORT TRUCK BODY....
the little brackets are a bit of a problem, so aluminum plate extends upon the back window, oh well.....
awoodman is offline   Reply With Quote
Old 12-29-2018, 09:01 AM   #2
Default Re: Trx4 sport truggy build
To turn the battery and keep it inside the cab and low as possible, I relocated the electronics.....
Old 12-29-2018, 12:29 PM   #3
Looks interesting. More sack then me when it comes to cutting stuff up. Could you bend the piece of aluminum going up the back of the cab to tuck inside the window?
BroncoAZ is offline   Reply With Quote
Old 12-29-2018, 01:58 PM   #4
The little 45angel brackets incorporated into top edge of the bed side and the back of the cab have to be trimmed off....So the aluminum plate has to extend up past the window to cover it.....
Old 12-29-2018, 02:06 PM   #5
Inside view...
Old 12-31-2018, 07:07 PM   #6
Battery tray out of aluminum....
Old 01-02-2019, 07:06 PM   #7
Front bumper...
Old 01-09-2019, 08:46 PM   #8
Looking good
shortbusjeep is offline   Reply With Quote
Old 01-11-2019, 10:44 PM   #9
Axial Honcho tail section fits...
Old 01-12-2019, 01:51 PM   #10
A new idea.....
Old 01-13-2019, 03:08 AM   #11
I dig your "bed sides"! Way to think outside the box!
coffeeaddict17 is offline   Reply With Quote
Old 01-20-2019, 10:54 AM   #12
Got overdrive gears installed
https://youtu.be/8dFMN50WV_I
Old 01-25-2019, 06:55 AM   #13
I like what you did with the bedsides on this build.
rkj__ is offline   Reply With Quote
Old 01-25-2019, 10:05 AM   #14
Forgive my ignorance... why do you guys call certain trail trucks truggy's? I know truggys as 1/8 race trucks...
furadi is offline   Reply With Quote
Old 01-25-2019, 11:25 AM   #15
Truggy: truck buggy truck cab buggy rear. Applies to any size vehicle
AnimalHippie is offline   Reply With Quote
Old 01-26-2019, 04:09 AM   #16
Cut the front fender flares down....
Old 01-26-2019, 08:01 AM   #17
I was still curious so I read the rules. Adding a back cage doesn't qualify as a truggy. Entire rear section needs to be tubed with integrated shock mounts and a roll bar.
I was curious because I just threw a back cage on my Sport.
Old 01-28-2019, 07:48 PM   #18
CRAWLING nothing but wood.....
https://youtu.be/miO5C9awj7I
Old 10-03-2019, 01:00 PM   #19
Yes you are correct. A true truggy would be rear tube chassis with shocks mounted to the cage. No rear frame section.
Trx4 sport truggy build - Similar Threads
Trx4 Sport build Shawns303 Traxxas TRX-4 15 01-12-2020 08:41 PM
TRX4 Sport Build puravida Traxxas Crawlers 6 05-02-2019 01:01 PM
Trx4 kit or trx4 sport mebeknob Newbie General 10 09-26-2018 10:38 PM
Harley Designs TRX4 Sport Mega Mud Truck Build Series ScoJac Traxxas TRX-4 24 07-08-2018 11:52 PM
