Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Any luck getting Canyon Trails off RTR Rims?
Old 04-01-2019, 10:22 AM   #21
Default Re: Any luck getting Canyon Trails off RTR Rims?
hobbyjumper, what tire are working the best in your area ??
sgtlt is offline   Reply With Quote
Old 06-05-2019, 01:31 PM   #22
I done heat gun for Axial rtr rims and boiling water for canyon trails. Both worked.., neither was very fun.
They are a large tire but sure do work!!
Not sure if it’s worth the effort.., in Canada most tire prices are ridiculous. If I were in the states., I’d buy scale licenced tires.
All the best
lkvisser is offline   Reply With Quote
Old 06-05-2019, 02:54 PM   #23
Dear god you should see what a heat gun does to her hair!!!
Browneye is offline   Reply With Quote
Old 06-06-2019, 02:19 PM   #24
I had great success baking them off...
1. Pre-heat the oven to 200C
2. Wrap each wheel in TWO layers of aluminium foil (keeps the smell to a minimum)
3. Bake for 5 minutes
4. Turn the oven off and leave them in for 30 minutes.
They peeled right off - no fuss. Use a towel though, the moisture in the foams will still be hot. And take them outside before unwrapping them - it stinks.
I also chucked a crust of bread in the oven afterwards to “soak up” the stink *BONUS POINTS*
-rc_oxo
rc_ox is offline   Reply With Quote
Old 06-09-2019, 10:56 PM   #25
Bake them off or use the desk lamp trick. Boiling sucks and doesn't work for me.
Old 07-20-2019, 06:52 PM   #26
I did mine a year ago with a heat gun. Ruined two wheels (remember shrinky din’s?) and the glue pulled two beads right off the tire. I really like the canyons but won’t be trying that again.
TroopThrowback is offline   Reply With Quote
Old 07-21-2019, 10:58 AM   #27
Originally Posted by hobbyjumper View Post
Next challenge is finding rims that fit. These are going back to the store.
RC4WD 5 LUG WAGON 1.9" STEEL STAMPED BEADLOCK WHEELS
There's a thread for it
TRX4 wheel fitment info
magic_yeti is offline   Reply With Quote
Old 07-21-2019, 11:20 AM   #28
Haha haha.., yep. I’ve never been so mad at a rim and tire in my life;).
1.55 rc4wd mt/r’s +1.55 rc4wd 5 lug wagons
= no beuno
Old 07-24-2019, 05:33 PM   #29
Awe some of my favorite looking wheels and super durable, but I've got several sets of the same in 6-lug.
Thanks! My problem is I'm not turned on by the fancy schmancy Method style rims everyone else digs. I like old school steelies that secure with five or six screws instead of a gazillion. I've got some from HR on order, as per advice from this forum.
Agreed on most of the uber fancy wheels and VP used to make them narrower than everyone which is not good, some of their newer wheels are proper width, but always check the specs.
Hot Racing and RC4WD stamped steel are my go to beadlocks!
Old 08-28-2020, 08:36 AM   #30
Finally was able to get the Canyon tires off the stock Defender rims.
Any advise on how to get the remaining glue residue off the tires? Looks like where I tried to wick acetone along the bead, there's some tough remaining residue there.
Real bugger getting these off.
>Heated in food dehydrator at 160F for 90 minutes - Nope
>>Wick acetone alone the rim with an old eye dropper. Multiple application over two days. Not budging
>>>Boiled in water for 20-30 minutes. Maybe loosened up 1 1/2 - 2 of the eight beads.
>>>>Heat gun. This finally worked but it took time and persistence.
OnTheTrail is offline   Reply With Quote
Any luck getting Canyon Trails off RTR Rims? - Similar Threads
Not having much luck with RTR electronics Spud805 Axial Yeti 9 01-09-2018 05:07 PM
If it weren't for bad LUCK I wouldn't have any luck at all redrokin00XJ Redcat Crawlers 10 02-06-2011 11:18 AM
