Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Motor plate idea
Old 03-14-2019, 10:11 PM   #1
Default Motor plate idea
I wonder if a motor plate/mount like this would be possible? I personally like to manually adjust spur and pinion mesh.
mud bogger is offline   Reply With Quote
Old 03-15-2019, 07:34 AM   #2
Default Re: Motor plate idea
I've been wanting a different mount since they came out. Being a little OCD I find it unacceptable to resort to shimming with tape, ect.
skybolt is offline   Reply With Quote
Old 03-15-2019, 07:51 AM   #3
Wish I had something like that for my Rock Rey. You can't really adjust it, it just bolts in and then you bolt down the belly plate and you hope everything stayed aligned.
mass-hole is offline   Reply With Quote
Old 04-01-2019, 10:36 AM   #4
Location: Taylors Falls just hanging with the MNRCRC crew.
I'd like to see a more adjustable motor mount for the TRX, it might quiet the gear noise a bit.
Stormin2u is offline   Reply With Quote
Old 04-01-2019, 12:08 PM   #5
Moderator
JatoTheRipper's Avatar
I changed out motors in my TRX-4 build this weekend. I am using the aluminum motor plate from Traxxas. Even with that metal plate there's still a hell of a lot of slop. It's unacceptable. It would be nice for a better motor mount, but it's not going to be easy since the lower half is build into the skid plate. And aluminum skid plates suck.
Old 04-01-2019, 04:46 PM   #6
Have a look at the Xtra Speed motor mount. It has a screw holding the motor plate in place and could be an alternative. http://www.rcmart.com/aluminum-motor...4-p-79608.html
Sent from my LG-H870DS using Tapatalk
brian.brigg is offline   Reply With Quote
Old 04-01-2019, 05:04 PM   #7
Moderator
I did see that. Thank you.
Motor plate idea - Similar Threads
i need a part # for a motor plate to fit a 1/8 brushless motor to my maxx mudd_slinger Traxxas Crawlers 1 03-10-2014 09:55 AM
AX10 Motor Plate/Motor Mounting Problems md7989 Electronics 8 11-25-2010 01:30 PM
New sig line/ License plate frame idea rckjeep Chit Chat 22 05-04-2005 01:07 AM
