12-19-2019, 04:32 PM | #1 |
Newbie Join Date: Mar 2013 Location: Apollo Beach
| TRX4 Sport Motor Mount Question
Hi all, I'm building the Sport kit. The motor seems to have several MMs of play in it. I know there are lots of you that run the stock set up so can I assume that slop isn't a problem? It seems that the pinion gear would be held at a slight angle to the spur gear. Also, it is difficult to ensure the mesh is good after the gear cover is installed. The kit also has a lot of plastic to plastic joints. Unfortunately I'm one of those guys that tightens his screws about 1/2 a turn too far. Is there a solid, direct, bolt-on upgrade for the motor mount that takes out the slop AND replaces the plastic gear cover with a metal one, as well as the brace? Thanks, Mr. Pickles |
01-09-2020, 06:22 PM | #2 |
| Re: TRX4 Sport Motor Mount Question
There are a number of aftermarket aluminum TRX4 motor mounts out there. Search ebay and Amazon.
01-09-2020, 07:49 PM | #3 |
The play in the motor bothers me as well. I just got a Traxxas aluminum motor plate, but the cover is still plastic so I have play. If I was ever going to get a metal motor cover I'd probably try the GRC version. More about that here: GRC motor mount? Last edited by JatoTheRipper; 01-10-2020 at 01:23 PM. |
01-09-2020, 08:31 PM | #4 | |
| Re: TRX4 Sport Motor Mount Question Quote:
Sent from my SM-G975U using Tapatalk | |
01-15-2020, 07:43 PM | #5 |
I have one of those GRC motor mounts as well and it is a really solid mount. It is easy to see and adjust the gear mesh.
01-15-2020, 07:56 PM | #6 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
I just put this Hot Racing mount on my Sport. It's identical to the stock motor mount. https://www.amainhobbies.com/hot-rac...xf1801/p733466 Sent from my LM-G710VM using Tapatalk |
TRX4 Sport Motor Mount Question - Similar Threads | ||||
trx4 sport kit - advise on motor and pinion | Bastiaan | Electronics | 9 | 08-26-2019 02:43 AM |
TRX4 Sport Portal Clearance Question | MaX-D | Traxxas TRX-4 | 2 | 08-21-2019 05:57 PM |
TRX4 Sport factory plastic wheel backspacing question.... | DougC | Traxxas TRX-4 | 3 | 06-13-2019 06:14 PM |
trx4 sport motor | floydtn | Newbie General | 4 | 02-18-2019 02:33 PM |
Trx4 sport motor | pyroM!KE | Traxxas TRX-4 | 4 | 02-06-2019 07:23 PM |
