06-20-2021, 11:46 AM | #1 |
Newbie Join Date: Oct 2019 Location: Ontario
| SSD Portal Delete Kit
Just wondering if anyone can comment on their experience with the SSD Portal Delete Kit and what modifications they made to use it successfully without burning out their motors etc.
06-21-2021, 07:38 AM | #2 |
| Re: SSD Portal Delete Kit
I swapped to a 9t pinion and run 4.6" tires... never had a problem. Never use second gear anymore though, just too tall w/o the gear reduction in the portals. |
06-21-2021, 11:00 AM | #3 |
Thanks for your reply... stock motor?
06-22-2021, 07:25 AM | #4 |
Initially outrunner, then stock, now running a Holmes Crawlmaster 550 15t Good reading, PDK install begins on post 83: OSRC's TRX-4 Defender "Greybeard" Last edited by OSRC; 06-22-2021 at 07:33 AM. |
06-22-2021, 01:50 PM | #5 |
Thank you kind sir.
07-07-2021, 10:57 PM | #6 |
Quarry Creeper Join Date: Jun 2018 Location: Blaine
I don't know if you're still looking for experiences or not but I run my TRX4 without portals as well. HW Axe R2 2800kv, 9t pinion (previously a HH puller pro 3200, iirc), 4.19 RC4WD Patigonia tires, YR aluminum axles for a bit of weight. My number tip, if you're going to run brushless (granted, my motor is probably overkill) be prepared to learn to deal with or tune out a lot of torque twist. Sent from my LM-V600 using Tapatalk |
SSD Portal Delete Kit - Similar Threads | ||||
SSD portal kit for SCX10 2 axle | Traulus | Axial SCX10 II | 66 | 02-10-2020 02:14 AM |
The SSD Portal Deletion | TinyJMods | Traxxas Crawlers | 5 | 10-17-2019 07:26 AM |
New SSD Portal Delete Kits | SSD | Traxxas TRX-4 | 33 | 08-04-2018 06:02 AM |
In Stock Now - New SSD Portal Delete Kits For TRX-4! | RPP Hobby | RPP Hobby | 0 | 02-08-2018 10:14 AM |
