Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Unlimited Class Crawlers
Thread: Dravpnir tries to build something Mini Unlimited
Old 09-01-2015, 01:56 PM   #1
DravTech
Dravpnir's Avatar
Default Dravpnir tries to build something Mini Unlimited
I have been saving parts since I saw MRCrackhead's Mini Super thread.
Today I managed to make some shortened axle tubes, so I guess this project has started officially then
The C-hubs are some Chinese brand ones which splines do not match, so you get different caster on the same axle... But as I got no splines on the shortened tubes they will work fine.
I need to see if they work like this, otherwise I got 2 pairs of axle tubes left for a second try.
I also got a bunch of Exceed parts to make up the rest of the axles. I got some plastic gears somewhere too. I was thinking of running metal large gears in the front and plastic ones in the rear.
For shafts I will use some OFNA shafts that I need to figure something out how to connect them to the Exceed locker or a standard Berg locker. Reason I went with OFNA shafts is because I got 2 extra pairs of Dlux delrin knuckles after upgrading to aluminum ones on my super.
Wonder were I put the 4th shaft and the knuckle arms...
For the chassis I will make something out of a SuDu Pro, perhaps like Hitman did.
I got no date when I am going to finish this, so do not expect it to be a fast build.
Dravpnir is offline   Reply With Quote
Old 09-02-2015, 12:06 PM   #2
Default Re: Dravpnir tries to build something Mini Unlimited
cant wait to see what you make out off these parts..
will follow this build closely,,
I have something like this on the "to do list" myself!!
I have a great feeling about a small super..
FLOKI-81 is offline   Reply With Quote
Old 09-02-2015, 12:57 PM   #3
Sounds like a cool build, Pictures don't work for me.
BC-Brian is offline   Reply With Quote
Old 09-03-2015, 07:27 AM   #4
DravTech
Dravpnir's Avatar
Thanks
Yes, they look like a lot of fun
You had the same problem with the pictures in the Super SuDu thread too, right? I do not know what it is I am sorry to say.
Do anyone else have problems seeing my pictures?
Old 09-03-2015, 07:44 AM   #5
Custom Carbon Fiber
Robbob's Avatar
Nope can see them all - thankfully too because I got the same cases at home and been wondering what to do with them
Robbob is offline   Reply With Quote
Old 09-03-2015, 09:06 AM   #6
Wanna get? Gotta want.
Erik D_lux's Avatar
What are those hubs for that are non 8* and have splines?
I think I will be a bit disappointed if you dont make a custom chassis! Not that its fair to put pressure on you but... you are such a great innovator that it would be a shame not to use your ideas to further this class. If its a problem with being 1 off and cost... let me know and I can see if I can help.
Erik D_lux is offline   Reply With Quote
Old 09-03-2015, 09:56 AM   #7
DravTech
Dravpnir's Avatar
Start building
Those are actually normal 8* chubs for wraith/xr10. They are from TopCad I think the company is called.
Soooo... you mean I have to draw up a SuDu SuperZero? Thanks! I think... well let see what I can think out and got time to
Hmm... I might have to pick you up on that offer then
Dravpnir tries to build something Mini Unlimited - Similar Threads
Dravpnir tries to build something small, again... Dravpnir Losi Mini-Rock Crawler 106 01-09-2018 10:07 AM
Dravpnir tries to build something Sporty Dravpnir Axial AX-10 Scorpion 19 09-10-2017 07:19 PM
Dravpnir tries to build something really small Dravpnir Losi Micro-Rock Crawler 7 03-11-2015 01:33 AM
Dravpnir tries to build something small Dravpnir Losi Mini-Rock Crawler 221 11-10-2014 02:28 PM
Dravpnir tries to build something even lighter Dravpnir EnRoute Berg 88 08-03-2014 02:58 PM
