Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vanquish Products VS4-10 Origin
Thread: VS4-10 Ultra Clearance Issues
Old 09-13-2020, 12:02 AM   #1
Default VS4-10 Ultra Clearance Issues
Im putting together an Ultra but somethings weird here with the clearnace. Does any one else have this issue with it hitting the panhard bar?
Another issue is the rear shocks are not straight up and down, they are at an angle. The Links are correct so I am not really sure here. Appreciate the help
LetsBash is offline   Reply With Quote
Old 09-13-2020, 06:24 PM   #2
Default Re: VS4-10 Ultra Clearance Issues
Well I don't have a ton of experience with the vs4-10 rigs I did just build an Ultra and mine does the exact same thing with the panhard and the rear shocks.
As far as the pan hard goes I'm saying it's normal. It's the left and right tire articulation you are more concerned about, not how far both tires travel up before hitting something. Most all frame mounted servo rigs do the same, that is something will eventually hit when compressing both tires.
Sent from my moto z4 using Tapatalk
hezzdown is offline   Reply With Quote
Old 09-19-2020, 12:33 AM   #3
Never noticed but I have the same issue on my Ultra as well. Haven’t noticed it to cause any performance issues though.
RCBrutus is offline   Reply With Quote
VS4-10 Ultra Clearance Issues - Similar Threads
VS4-10 Ultra Help TwiztidDevil Vanquish Products VS4-10 Origin 15 04-28-2020 11:25 AM
Problem VS4-10 Ultra mlcepeda Vanquish Products VS4-10 Origin 7 04-22-2020 12:53 AM
VS4-10 Ultra Topher Builds General Crawlers 109 01-25-2020 07:56 AM
