04-20-2020, 05:48 PM | #1 |
Newbie Join Date: Feb 2013 Location: Fairfield
| Problem VS4-10 Ultra
My Kit runs great except when I steer it right or left. The motor does not run smoothly. It’s jerky. Goes fast then slow then fast. It only happens when I steer it. What is my problem? I have a Tekin 3100kv and RX4 esc installed.
04-20-2020, 06:07 PM | #2 |
Quarry Creeper Join Date: Mar 2010 Location: Yay Area
| Re: Problem VS4-10 Ultra
Welcome to the sight! You are going to get more questions than answers dude. Post more info if you can. You'll get better answers. What servo are you using? Batteries? Is your electronics brand new? Are the leads attached correctly? Using a BEC by any chance? |
04-21-2020, 07:49 AM | #3 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
| Re: Problem VS4-10 Ultra Sounds like you are binding the CVDs in the front axle. Might need to back the EPAs off a little to keep them from binding.
04-21-2020, 05:22 PM | #4 |
What does EPA stand for? Sorry, I guess I’m a newbie.
04-21-2020, 09:09 PM | #5 |
Rock Stacker Join Date: Jun 2017 Location: US
| Re: Problem VS4-10 Ultra |
04-21-2020, 09:54 PM | #6 |
Rock Stacker Join Date: Nov 2009 Location: Santa Rosa, CA
Have you checked your center driveshafts to make sure they are phased correctly? Check to see if both “U shape” joints are inserted in the slider at the same angle so they mirror each other. Sent from my iPhone using Tapatalk |
04-22-2020, 12:31 AM | #7 |
Newbie Join Date: Mar 2020 Location: Chandler AZ
On my rock jock I had to put shims between the mip driveshaft I bought and the pinion
04-22-2020, 12:53 AM | #8 |
Pebble Pounder Join Date: May 2015 Location: UK
Could be a brown out
Problem VS4-10 Ultra - Similar Threads | ||||
VS4-10 Ultra! Murda Edition! | Angelowaslike | Vanquish Products VS4-10 Origin | 21 | 04-28-2020 08:51 AM |
SCX3 vs VS4-10 Ultra | photocycler | Axial SCX10 III | 2 | 04-02-2020 02:24 PM |
VS4-10 Ultra | Topher Builds | General Crawlers | 109 | 01-25-2020 07:56 AM |
VS4-10 Ultra Kit Transmission? | sherbs | Vanquish Products VS4-10 Origin | 14 | 01-17-2020 05:58 PM |
