01-17-2023, 11:51 AM | #61 |
Quarry Creeper Join Date: Dec 2022 Location: Akron, Ohio
| Re: Steve's VS410 Phoenix Build |
01-17-2023, 12:08 PM | #62 |
Quarry Creeper Join Date: Dec 2021 Location: Glendora
Thanks.
01-20-2023, 09:19 AM | #63 |
My shocks arrived, but no sign of my cantilever kit. So I called Dinky RC, we talked for a few about the cantilever kit. I learned that the cantilever kit was designed to use 1/16 scale 50mm shocks (shocks not included with kit), the website only states that the shocks needed are 50mm. Dinky said that he would look into that. So my big bore shocks might not fit as they are bigger than the VP stock shocks that might not fit either. But B-MOW71 used the VP 80mm stock shocks though not as intended, (good job on that too) he also didn't use the Dinky kit. I'm going to play around with them and I'm sure I can make the kit work one way or another. Dinky said they might ship as early as this Monday. With the weather being the way it is and knowing if paint freezes it might ruin it. Painting is on hold till better weather. This will give me time to acquire the rest of my electronics. |
01-20-2023, 09:49 AM | #64 |
Good info there on the DinkyRC cantilever kit. I didn't realize it was designed for 1/16 scale shocks either. If you can't get the Dinky kit to work, the cheap kit that I bought does seem to work good and may work for you too. My VP shocks are actually the 90mm S8E shocks that come with the straight axle kit. I do plan to limit them to 80mm or possibly less with fuel tubing inside the shocks to get rid of the massive flex that it has now. Hey looks like we both missed our window of opportunity to apply paint yesterday. It sure was nice out until the storms rolled in! |
01-20-2023, 10:51 AM | #65 | |
| Re: Steve's VS410 Phoenix Build Quote:
I didn't know those were 90mm. I saw that the rocker arm protruded above the frame when compressed. Can't have that on a flatbed, though I do intend to have a rail on top of the frame to support the bed which will give me a little leeway on travel. My next rig will be a Phoenix or yota flatbed with a VFD Transmission so no tool box servo and Currie D44 axles. I do have a question. With the parts listed above and using a yota body. What would be the best way to purchase this. Should I just get a Phoenix straight axle kit, chassis kit or piece it out. | |
01-20-2023, 12:28 PM | #66 | |
negating the need for a rail at all. But I'm looking for scale looks so probably will have a rail. I also plan on using the Incision steel driveshaft set if I can make that work. | |
01-21-2023, 01:52 AM | #67 |
My DinkyRC cantilever kit has shipped, it will be here Monday. I was sitting at my workbench, holding up my 50mm shock against the stock shock comparing them. Holding the 50mm shock flush with the bottom of the stock shock. I looked up and saw that the top of the 50mm shock lined up with the rail. I said to myself no way. I can't believe I didn't think of this configuration earlier. I removed the stock shock, then I popped the bottom stock pivot ball into the 50mm shock. The pivot ball was slightly bigger than the hardware that came with the 50mm shocks but it worked. I used the hardware that came with the 50mm shocks for the top pivot ball. I removed the shock tower, and installed the 50mm shocks. If need be the shock tower could have been left in place. I used the M3X20mm from the top of the shock tower to secure the top of the shock and used the stock M3X20mm cap head for the bottom. After installation of the 50mm shock, I held up the stock 80mm shock in the same manner as before. I saw that if I had a rail on top of the frame for a flatbed the 80mm stock shock would work if attached to it. It would be slightly longer than needed but I believe the weight of the flatbed would make the flatbed drop down just about right if not it wouldn't be much. Anybody need a DinkyRC cantilever kit. I did use a threaded pivot ball for a spacer against the rail and a M3x25mm should be used instead of a M3x20mm. The top of the shock is 1mm below the top of the rail. Last edited by Steven McKay; 01-21-2023 at 02:26 AM. |
01-23-2023, 02:06 PM | #68 |
More info on image (50mm big bore shock) in post #67. First, If I was going to use this setup. I would replace the threaded pivot ball I used as a spacer (all I had at the time) with a spacer from the Rock Pirates servo & shock spacer pack. Second, the 50mm big bore shocks came with three spring sets. I used the light (green) spring set. They (green) were still pretty stiff but usable. The 50mm big bore shocks don't give you a lot of travel if that is of concern. I think with a lighter spring set, they would work just fine. My cantilever Kit arrived this morning. Just remember I didn't know the cantilever Kit was designed for 1/16 scale shocks (not listed on website) and possibly the entire unit, until I talked to Dinky RC about when it might be shipped. At the time I figured that the only problem I would encounter would be the larger dia. shocks. But I was wrong, the screws for the mounting bracket are of a smaller dia. and won't fit the rail. Not only that but the holes don't line up either, very close thought but no cannoli. I could fix that by drilling my own holes. Secondly, the shock pivot ball is to wide to fit, I could buy thinner pivot balls or I could pull out the 1x30 and take off a little on both sides. Thirdly. The mounting bracket is to wide (wider than the one B-MOW71 used) to allow the shock to move freely, again 1x30. That's a lot of work, when you can simply go to Amazon and get a 1/10 scale cantilever Kit. Like the one B-MOW71 bought. Amazon has two cantilever Kits. One for the SCX10 and the one I would get because I don't do Amazon and found it elsewhere is for the SCX10 II, this one: RCLions 2pcs RC Shock Absorber Damper 70mm Cantilever Suspension Kit for Axial SCX10 II 90046 Upgrade Parts 1/10 RC Crawler Car. I most likely won't be using a cantilever on my flatbed build. I'll simply attach the 80mm-90mm shock to the axle (stock) and to the rail using a spacer from Rock Pirates. Same way as above in post #67 but not the frame the rail I'll mount on the frame. No pivot ball in image below won't fit. Last edited by Steven McKay; 01-23-2023 at 02:23 PM. |
01-26-2023, 10:52 PM | #69 |
Not a whole lot to post. I put the stock wheels on, just for looks. Ok, I just wanted to play with it beats hot wheels. I also decided to get the FS- GT5 and either the FS-BS6 or FS-iA6 for now. I'll save money and be able to get the rest of what I need to finish this beast. Can't paint so if I have some cash left over, I'll start getting parts for my flatbed. |
01-30-2023, 09:43 AM | #70 | |
Sounds like you may want to piece together the new rig. Since you are wanting the D44 axles and the VFD trans, the only way to get them now is to buy them separately. You could buy the VS4-10 PRO which comes with the upgraded VFD trans, but has the Currie F9 axles. The F9 axles look great and are beefy, but the D44 just look more scale. The PRO kit would be more expensive, but you would get most of what you want except for the D44 axles. The other downside IMO is that the PRO comes with the Incision shocks and not the S8E shocks that come with the Phoenix. The Incision shocks that came with my Origin and PRO always leaked and I could never get them to hold oil. | |
01-30-2023, 07:06 PM | #71 | |
01-30-2023, 08:49 PM | #72 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
Fyi the front axle will follow the arc of the panhard bar a significant amount. I wouldn’t worry too much about adjusting it until you see where it lands at normal ride height, i.e. with the full weight of the body, electronics and battery. Also, if the shifting of the axle concerns you, just remember that basically never will the suspension compress or drop equal amounts one side to the other. Normal suspension movement will cause one side to be up and the other down. As far as the rear shock/cantilever setup, i will share something I’m working on in case it’s relevant to anyone. I’m fitting a Mojave body to a Phoenix straight axle, and I opted to use 80mm shocks with the optional -5mm lower rod end mounted to the link, along with a simple upper shock mount. Upper mount is 3D printed, but I will have it cut from aluminum or carbon fiber later. Sent from my iPhone using Tapatalk |
01-30-2023, 08:56 PM | #73 | |
I think I would buy a Phoenix straight axle kit, sell the body, sell the twin (if you want a standard vfd) and then buy the d44 housings and the body of your choice. By far cheaper than piecing everything together. Sent from my iPhone using Tapatalk | |
01-30-2023, 10:45 PM | #74 | |
01-31-2023, 09:22 AM | #75 | |
I'm going to have to see more of this build!! | |
01-31-2023, 12:58 PM | #76 | |
01-31-2023, 02:10 PM | #77 | |
I went back and see what you mean I wouldn’t call it the mistake of the year, but pretty funny anyway Sent from my iPhone using Tapatalk | |
01-31-2023, 03:05 PM | #78 |
| Re: Steve's VS410 Phoenix Build Had to pull all my wheels and shocks off, because I had to lower the top collar and tighten the spring. Didn't want the cap to loosen or tighten up. All fixed now. |
02-01-2023, 06:11 AM | #79 | |
It's all good and that is how we learn! I've made similar mistakes along the way as well! | |
02-03-2023, 10:47 AM | #80 |
Trying to find out what link set to use for VFD trans and D44 axles. I don't think it makes a difference between the VFD and the VFD twin. According to VP the link set to use is the INCISION TITANIUM VS4-10 PRO 10PC LINK KIT IRC00300. Is there a stainless steel version? Can I use the INCISION VS4-10 F10 1/4 STAINLESS STEEL 10PC LINK KIT IRC00303?
Steve's VS410 Phoenix Build - Similar Threads | ||||
RedHarris's VS410 Phoenix Build | Redharris | Vanquish Products VS4-10 Origin | 1 | 11-20-2022 08:31 AM |
Doomp's VS410 Phoenix | Doomp | Vanquish Products VS4-10 Origin | 40 | 04-08-2022 10:15 AM |
Woodys Vs410 Phoenix build. | KyWoody | General Crawlers | 2 | 03-17-2022 12:34 PM |
VS410 Phoenix? | Doomp | General Crawlers | 23 | 03-15-2022 08:13 AM |
