04-17-2023, 01:47 PM | #61 |
Rock Crawler Join Date: Jan 2022 Location: st louis
| Re: Steve's VS410 Phoenix Build II
Oh I'm loving that tailgate Sent from my SM-S906U using Tapatalk |
04-17-2023, 03:45 PM | #62 |
Quarry Creeper Join Date: Dec 2022 Location: Akron, Ohio
| Re: Steve's VS410 Phoenix Build II Thanks. And I couldn't resist another bedcover to cover the clutter. Flat dark earth-fall. The tailgate was made from 550 cord with the internal cord removed and a little superglue.
04-18-2023, 06:21 AM | #63 |
| Re: Steve's VS410 Phoenix Build II |
04-21-2023, 08:22 PM | #64 |
| Re: Steve's VS410 Phoenix Build II Thanks. Almost finished, I kinda got a wiper outa wack. Wonder what I was smoking.
04-21-2023, 09:56 PM | #65 |
RCC Addict Join Date: Dec 2012 Location: Crookston
Looking good. |
04-22-2023, 05:55 AM | #66 |
04-22-2023, 04:04 PM | #67 |
Rock Crawler Join Date: Nov 2019 Location: Erie
04-22-2023, 04:48 PM | #68 |
| Re: Steve's VS410 Phoenix Build II Thanks, it's coming together. It was Purple swashy and I was swashed. It's in the mail, I swear. The body is finished..............for now. I added anti skid plates to the rear fenders, I'll blacken the screws. Think I'll change the wheels, get studs and bolts and black caps. Then I added a little flair. |
04-23-2023, 07:55 PM | #69 |
I have finished my rig and test drove it. We have a problem Houston. The right side of the body lifts up when I go into reverse. At first I thought the body was rubbing on the tires but that is not the cause even though I have the shocks mounted with the low rod ends. I also noted that the G8 tires seem to grab the carpet a lot more than the predator tires on my portal even crinkling when in a tight turn. Then I started to think (not done often) about it and then it hit me, it must be the panhard link and possibly the drag link. I took a look at how they are and it does look like they could be extended, I believe I have them screwed almost tight like the portal. So if someone could confirm my assumption before I start working on it, it would be appreciated.
04-25-2023, 03:20 PM | #70 |
Still looking for help, I took off the drag and panhard link and they are just barely short of stock spec. Take note that I used these shorter rod ends for the shocks. Instructions say you can shorten the links for shorter shocks. But I still don't know which way to go longer or shorter. This post follows above post, read post 69 first. Thanks. I think the drag and panhard link should be extended but things are not always the way they seem.
04-26-2023, 05:39 AM | #71 |
Newbie Join Date: Apr 2023 Location: elk grove
when adjusting panhard/ steering, look at your truck from the front with steering centered, each front shock should be the same distance from the frame, vertically each shock should be straight up/down
04-26-2023, 06:17 AM | #72 |
edit-when doing this check make sure your lower shock pivot balls are the same on both sides, just want to center the axle and this is the only way I know to do this.
04-26-2023, 06:22 AM | #73 | |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
| Re: Steve's VS410 Phoenix Build II Quote:
Are you only noticing this on a high traction surfaces like carpet? Also what o/d % is the trans in? I’m wondering if it could be a normal characteristic based on o/d and high traction causing the front suspension to lift since the front tires are trying to move faster than the rear. Sent from my iPhone using Tapatalk | |
04-26-2023, 09:58 AM | #74 |
Twade is correct due to torque twist in reverse, the right side will lift, in forward the driver side will lift. this is more predominate in straight axle versus portal due to the gear reduction in the portals
04-26-2023, 10:45 AM | #75 | |
Thanks. I believe your both right, it's natural for this to happen. Now that I think about it I think my portal did this too but to a lesser amount. I was going to get my portal out today and see how much it lifted up. I had taken off both links and added two turns, to no avail. Before I did this the alignment was fine so I'll just put it back the way it was. One problem I discovered is whenever you start flipping your rig over to work on it the shocks start leaking. I'm going to have to find better shocks. Thanks again guys. | |
04-26-2023, 11:19 AM | #76 | |
I’ve had several sets of s8e’s leak at the bleeder screw, the screws tend to strip the threads in the cap before tightening enough to seal anything. I’ve also had one whole cap come loose somehow. If yours are leaking there also, you might try the machined aluminum caps VP sells for them Sent from my iPhone using Tapatalk | |
04-26-2023, 11:56 AM | #77 | |
04-27-2023, 04:47 PM | #78 |
I tightened the shock collars down about halfway on the portal to compensate for the heavier tailgate. Did the same for the straight axle. Took the straight axle out for a it's first spin around the backyard rock course. It did surprisingly well, I think it has better stock foams than my Hyrax tires. I haven't dived into different foams yet just stock. But the PL BFGoodrich Krawler T/A KX tires seem to have good foams and they grab very well. Yea I'm happy.
05-03-2023, 01:09 PM | #79 |
I decided to use the same tag as my portal, so I had Ohio change the law since I'm a VIP and all. |
05-03-2023, 05:23 PM | #80 | |
Glad to hear you had them change the law. Most all of my rigs run the same plate. Good thing I only drive one at a time! | |
Steve's VS410 Phoenix Build II - Similar Threads | ||||
Steve's VS410 Phoenix Build | Steven McKay | Vanquish Products VS4-10 Origin | 175 | 05-03-2023 05:25 PM |
RedHarris's VS410 Phoenix Build | Redharris | Vanquish Products VS4-10 Origin | 1 | 11-20-2022 08:31 AM |
Woodys Vs410 Phoenix build. | KyWoody | General Crawlers | 2 | 03-17-2022 12:34 PM |
VS410 Phoenix? | Doomp | General Crawlers | 23 | 03-15-2022 08:13 AM |
