Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Ascender
Thread: hot racing upgrades
Old 03-14-2015, 08:48 PM   #1
Default hot racing upgrades
just saw these. didnt see it on ebay but that have diff covers too.
Hot Racing Vaterra Ascender Aluminum Front Knuckles VTA2101 | eBay
Hot Racing Vaterra Ascender Aluminum C Hubs VTA1901 | eBay
hope to see some over under gears.
m1009cucv is offline   Reply With Quote
Old 03-15-2015, 09:33 AM   #2
Default Re: hot racing upgrades
Purchased and eagerly awaited lol
MudMonster is offline   Reply With Quote
Old 03-19-2015, 08:31 PM   #3
It doesn't appear there parts work with the brake rotors, but otherwise don't seem too bad
tgh117 is offline   Reply With Quote
Old 03-20-2015, 06:19 AM   #4
i didnt think of that. mine are on the way. hope they work with the rotors
Old 03-20-2015, 06:41 AM   #5
I have the Vaterra parts & rotors on my Ascender and it doesn't look like the rotors will work with the HR hardware.
IronGut is offline   Reply With Quote
Old 03-25-2015, 01:32 PM   #6
nope hr parts dont work it looks. rotors are alot of $$. think ill just add more to the wheels
Old 04-05-2015, 06:32 PM   #7
I am wondering if the diff covers they make will improve gear durability.
Old 04-06-2015, 07:41 AM   #8
i dont see how they would. i thought they hold the bearings in place
Old 04-06-2015, 09:22 PM   #9
Someone else wrote about possible housing flex increasing the gears chance of breaking. After swing the design I think the metal would at least offer a little extra support on the spool. If you pull the diff cover, push on one of the wheels the spool jumps right out, now if the plastic diff cover can somehow deflect s bit, that will increase the slop in the mesh every now and then. It was just s thought. I will try them, can't hurt.
Old 04-10-2015, 07:35 AM   #10
only ran mine a few times.. didnt know that. good to know
Old 06-28-2015, 04:49 PM   #11
Natedog's Avatar
Nice to see more vendor options, their diff covers are very nice! I compared their knuckles and c-hubs with the Vaterra aluminum and Vaterra are thicker on steering arms and where pivot (steering) bushings ride, therefore I will buy Vaterras.
Update?
Too much wheel weight is not good, I don't like 1.9 wheels over about 90 grams each.
Yes, they hold the bearings in place which hold the gears in place. Also help reduce any flex of the axle housing center section, both help keep gears in proper alignment and mesh.
That was me in the HD pinion/broken pinion thread and iirc saw somebody else said it too. As you said about the spool kinda drops right out, but you don't want it too tight. I used the HR aluminum diff covers and shimmed both diffs too.
hot racing upgrades - Similar Threads
Hot Racing Links are hot mess!! Sethmetal Axial Wraith 53 04-12-2013 12:27 PM
Hot Racing upgrades Toppy 1.9 Scale Rigs 0 02-05-2011 11:25 PM
Hot Racing upgrades ??? Frank Rizzo Axial XR10 15 11-10-2010 07:48 PM
