12-18-2014, 06:45 AM | #81 |
Rock Crawler Join Date: Feb 2007 Location: Crawling Around
| Re: GCM's 1986 M1009 Blazer Build
Time for exhaust. This was a bit of a pain.. I tried to make this fit when the interior panel was on, and I couldn't get it all around the frame and stuff, so it was time to get it done now. There's only one attachment point, as I pancaked the one end of the exhaust tube and drilled a hole in it and screwed it to the top of the Tcase mount bolt. This works great by holding it flat, and keeping it from twisting around. Kind of a nice accident it worked out this way! While I was in there, I put the linkage on for the 2 speed shifter. It's a 9 gram HXT servo, and the stock horn, and then a 1/32 bent solid airplane wire for the pushrod. Lots of power for a tiny shifter mechanism. I married the pushrod to the trans with a wheel collar. |
12-18-2014, 06:45 AM | #82 |
The end result of all that is the truck is back together better than ever. I've got some more details done, and it's running good. ALmost done.... |
12-18-2014, 10:12 AM | #83 |
Quarry Creeper Join Date: Sep 2007 Location: Hancock MD
Keep up the work man, all these details add up on this thing. PS. I cant help it.... looks like that guy had an exhausting day at work. |
12-20-2014, 10:52 AM | #84 |
Dana got his running now, so we have another update video! https://www.youtube.com/watch?v=8tCh3hBIEEM |
12-20-2014, 07:09 PM | #85 |
| Re: GCM's 1986 M1009 Blazer Build Where did you get those drivers?
12-20-2014, 09:45 PM | #86 |
Quarry Creeper Join Date: Feb 2011 Location: Forbestown, CA
I never once met someone who chromes or cleans to a polish a exhaust on a gmc from the 80s always a first looks good also! I like the set up.
12-20-2014, 11:37 PM | #87 |
Cool video, the trucks both look great! If you are ever bored (and you would have to be very bored) you could try to bend up a flat bar grille guard like the mil spec's usually had. I dont think the truck really needs it as the bumpers look great by themselves but it could add one more little touch and even protect the grille you put so much work into. I found the vid really cool, I have had a ton of blazers including military and also one of my favorites was a 77 that was yellow and white though mine was butternut yellow not a mustard color. Last edited by 350TacoZilla; 12-20-2014 at 11:44 PM. |
12-21-2014, 05:38 AM | #88 |
Thanks for the comments, guys! I'd really like to make a thin metal grille guard for this, but I'd have to get some brazing stuff together and likely make it from brass anyway. I would like steel, but don't think I can get some decent pre-sized material that small. I don't want to have to strip it all from sheet and then try to make it straight and clean after. I'm sure the exhaust pipe will be dirty soon enough! It's a fresh install afterall! haha |
12-21-2014, 06:10 AM | #89 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
That thing came out great guys , Do you use stencils on the paint , And is it painted on the out side ?
12-21-2014, 06:12 AM | #90 |
Thanks, you old man! Rich painted the camo on the outside, using a pencil to outline stuff after spraying the base coat of green. The colors were brushed on the outside after wards by hand. Not as precise as a stencil for sure, but works great.
12-21-2014, 06:33 PM | #91 |
How about wiper blade inserts for the grille guard metal? they are usually steel and might be around the right size. (cheap too if you shop bargain stores)
12-21-2014, 06:34 PM | #92 |
Hmmmmm. That's a really good tip!
12-22-2014, 08:50 AM | #93 |
Rock Crawler Join Date: Aug 2012 Location: 909 area
Build is awesome
12-22-2014, 11:12 AM | #94 |
Rock Stacker Join Date: Nov 2014 Location: SoCal
Details are awesome. My only question is the exhaust. Mine comes out on the drivers side on my '87. Is it different on the MIL ones? |
12-22-2014, 04:43 PM | #95 |
I doubt it, you're likely correct. Maybe the pics I found are reversed!
12-23-2014, 07:14 AM | #96 |
The tell tell sign is to look for the fuel filler door. It's on the passenger side. ;)
12-23-2014, 07:15 AM | #97 |
Of course! Great tip! That's what you get for never owning a Chevy! haha!
12-23-2014, 08:05 AM | #98 |
If you got questions or need pics, just let me know. Being mine is a '87 it is basically the same as the '86. And there are some old Mil Chevy trucks around where I work as well. I could beat you up more on the interior but I wont. ;) I love all of the thought and detail you've put into it. Way more than I'll ever do. So no tire rub on the body? I went and trimmed off just a little on the back of the front wheel opening and the font of the rear opening. Not much but just enough to clear the tires. I didn't want to narrow the axles any. Last edited by Crusty Old Shellback; 12-23-2014 at 08:09 AM. |
12-23-2014, 08:29 PM | #99 |
No tire rub here, but it's a small tire for sure.
12-23-2014, 09:21 PM | #100 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
As to the exhaust issue.....just add a left side for true dual's! And with you most awesome fab skills - it would expect a set of 1:10 scale Flowmasters! Lets get crackin!
GCM's 1986 M1009 Blazer Build - Similar Threads | ||||
RCBuzz - Vaterra Ascender (1986 Chevrolet K5 Blazer) | RCBuzz | Vaterra Ascender | 2 | 11-12-2014 09:15 AM |
Badger's 1986 Chevrolet K-5 Blazer Ascender | badger | Vaterra Ascender | 3 | 09-30-2014 12:16 PM |
River Ridge #9 - Dana's Blazer and GCM's Hilux Vid | Generis | Scale Videos! | 0 | 09-27-2013 10:06 AM |
1986 suzuki samurai build | neightfrog | 1.9 Scale Rigs | 32 | 06-12-2009 02:16 PM |
