03-26-2015, 09:52 PM | #1 |
Newbie Join Date: Feb 2015 Location: Johannesburg
| Tires in kit
Has anyone tried to put the tires that come in the kit on a beadlock wheel with any success? It looks like they might be a glue only style of wheel. I was wanting to try and put them on a beadlock wheel so that if I wanted to change them out easy I could.
03-26-2015, 10:55 PM | #2 |
Rock Stacker Join Date: Jan 2012 Location: Canada
| Re: Tires in kit
Yep, Mine are on GCM racing wheels (internal beadlock). They fit no problem.
03-26-2015, 11:18 PM | #3 |
Pebble Pounder Join Date: Jul 2013 Location: Central Rockies
| Re: Tires in kit
The tire beads are little thicker than most tires, I have had success mounting them on wheels such as, VAnquish method 105, and some SSD assassin. However i didn't have very good luck trying to mount them up on wheels like axial 8 holes and basically any wheel with a narrow channel for the bead to sit into. That's just my 2 cents, hope it helps |
03-27-2015, 06:07 AM | #4 |
Pebble Pounder Join Date: Nov 2010 Location: wyatt
| Re: Tires in kit
had no problem mounting them on axial 8 holes. threw some CI DW foams in there and they work well for me.
03-27-2015, 06:21 AM | #5 |
| Re: Tires in kit Same for me, no problems on the Axial 8 hole wheels. I even tried them on an old pair of Axial 2.2 beadlocks to see how they look. They looked awful but they mounted up no problem.
03-27-2015, 07:29 AM | #6 |
RCC Addict Join Date: Nov 2010 Location: England
| Re: Tires in kit
Gear Head Trail King wheels on mine and they were a good fit. Gear Head RC 1.9 Trail King EZ-Loc Wheels (4) |
03-27-2015, 12:07 PM | #7 |
| Re: Tires in kit
Hi, i put them on Pro10 1.9 RC4WD Wheels. It worked but was not so easy, ended up with longer screws to tighten them first and later used the original ones. Pro10 1.9 Steel Stamped Beadlock Wheel (Silver) |
03-27-2015, 08:35 PM | #8 | |
Pebble Pounder Join Date: Oct 2010 Location: Marengo Oh
| Re: Tires in kit Quote:
03-30-2015, 11:15 AM | #9 |
Rock Crawler Join Date: Jun 2007 Location: Working in my dream RC workshop and remodeling my entire home.
| Re: Tires in kit |
06-18-2015, 12:01 PM | #10 |
| Re: Tires in kit The SSD beadlocks have been great wheels for me, they are relatively easy to mount tires, look great and take a beating! |
06-18-2015, 12:42 PM | #11 | |
Rock Stacker Join Date: Jun 2015 Location: K
06-19-2015, 07:25 AM | #12 |
Pebble Pounder Join Date: Sep 2012 Location: Netherlands
| Re: Tires in kit
I used Gmade 1.9 VR01 beadlock wheels, not a problem.
07-03-2015, 04:06 PM | #13 |
| Re: Tires in kit Those and the Proline Faultline look real nice and should be lighter weight if that's what you want, has anybody painted them with success? They would look good with centers painted silver, gold maybe or color match to truck.
07-03-2015, 08:22 PM | #14 | |
07-06-2015, 11:47 AM | #15 |
| Re: Tires in kit |
07-06-2015, 01:21 PM | #16 |
Rock Crawler Join Date: Mar 2012 Location: UK, Hampshire
| Re: Tires in kit |
07-07-2015, 09:41 AM | #17 |
| Re: Tires in kit |
07-07-2015, 09:56 AM | #18 |
Quarry Creeper Join Date: Apr 2011 Location: bay area
| Re: Tires in kit
I remove the chrome before painting anything. I just repainted the diff covers. I use acetone to remove the chrome.
07-07-2015, 09:58 AM | #19 | |
I think as long as you use a plastic paint then you shouldn't run into any trouble, I've used tamiya paint previously on pl titus wheels with success | |
07-07-2015, 10:18 AM | #20 |
| Re: Tires in kit Thanks, yours came out very nicely that's why I asked. It can be difficult to spray small parts with lots of nooks and crannies...too much and it runs, but too little and the corners and all don't get coated.
Tires in kit - Similar Threads | ||||
Kit tires vs tsl | EMUTT | Axial Wraith | 38 | 02-09-2012 07:42 PM |
2.2 tires on AX10 kit HELP!!! | jmthompson | Newbie General | 19 | 12-14-2010 02:39 PM |
The tires in the kit... | h8z2luze | Team Losi Comp Crawler | 5 | 06-24-2009 09:17 PM |
Tires in AX-10 kit | 666 | Axial AX-10 Scorpion | 10 | 08-27-2007 10:21 PM |
