05-27-2015, 02:02 PM | #1 |
Quarry Creeper Join Date: Aug 2014 Location: Chilliwack
| Rear wheels spinning freely
After my recent trail run I'm having an issue with my Ascender. When I spin the rear wheels by hand, they spin freely ( with the rear drive shaft), and do not engage the front tires. But when I spin the front tires, the rear tires engage. Am I right to believe there's an issue in the transmission? If so, anyone know what it might be? |
05-27-2015, 06:45 PM | #2 |
| Re: Rear wheels spinning freely
Sounds like the set screws on your driveshaft cups loosened up.
05-27-2015, 06:53 PM | #3 |
Rock Crawler Join Date: Jul 2005 Location: MD
| Re: Rear wheels spinning freely |
05-28-2015, 01:01 AM | #4 |
Quarry Creeper Join Date: Oct 2012 Location: Canada
The output shaft on the transmission is a one piece shaft that powers the front and the rear. And I don't think you can break it. So the next option to check is the set screws at the tranny output.
05-28-2015, 09:35 AM | #5 |
Thanks guys. I'm new to the hobby so this forum is super helpful. I'll check it out tonight, hopefully it's a nice easy fix.
05-29-2015, 05:39 PM | #6 |
Rock Stacker Join Date: Jun 2010 Location: Goodyear/ West Phx
Hey Smonkman, my set screw came loose last weekend on my rear driveshaft. If this is the same for you, it's a simple fix. Just take a look at where your driveshaft connects to the tranny. There's a little set screw that attaches the driveshaft to the transmission output (has a flat side the screw tightens to). Make sure that screw is tight, and make sure it's hitting on the flat side of the output, otherwise it will just spin.
05-29-2015, 11:34 PM | #7 |
Pebble Pounder Join Date: May 2011 Location: Santa Cruz, Ca.
Same thing happened to me when I first started running my RTR. Tightened up the set screw, but came loose a couple weeks later. Just put a small drop of threadlock on the screw and won't come loose again. Good idea to do the front too if you don't carry many tools with you when you go out to run it away from home.
Rear wheels spinning freely - Similar Threads | ||||
Front spinning faster the rear. | OCscx10 | Axial SCX-10 | 5 | 10-12-2011 01:40 PM |
Front Motor Spinning Before Rear | brazwewn | Electronics | 3 | 05-11-2011 05:40 PM |
Spinning rear motor - no spinning rear wheels | Sno Dawg | Redcat Crawlers | 13 | 04-24-2011 08:45 PM |
should these axles be spinning freely? (freewheeling) | 53 willys | Axial XR10 | 14 | 10-31-2010 08:47 AM |
Rear wheels not spinning | RTVIC | Redcat Crawlers | 19 | 05-30-2010 07:01 PM |
