07-04-2015, 09:52 AM | #1 |
Rock Stacker Join Date: Jun 2015 Location: K
| Ascender Aluminum Rock Sliders
Never liked the plastic Vaterra rock sliders that come on the rig, so I made my own out of 1/16" thick aluminum plate. Actually just ordered the plate to the dimensions (1/16" x 3" x 6") I wanted to tuck between the wheels. Bent the plates in my 6" vise and measured the corners and bent them up to follow the frame and keep from catching on rocks. I like the way they turned out, and they work well on the rocks. Note that if you want to make these yourself you may need a different width. Mine were measured to fit my Pro-line Jeep Cherokee body which is smaller width then the stock blazer body. Last edited by stillsmokin875; 07-16-2015 at 10:57 AM. |
07-04-2015, 03:57 PM | #2 |
Pebble Pounder Join Date: Jan 2015 Location: Calgary
| Re: Ascender Aluminum Rock Sliders
Looks good. I'm planning to do somthing very similar but ill be putting axial battery plates on the top of each of the supports so i can run bigger batteries.
07-04-2015, 04:34 PM | #3 |
| Re: Ascender Aluminum Rock Sliders As small as the lipo's I'm running right now are, I could mount a pair of them on the sliders as well. Might try that out and see how it works.
07-05-2015, 09:16 PM | #4 |
Pebble Pounder Join Date: May 2014 Location: Floriduh
This is good to see as I need to figure something out for my JKU bodied ascender!
07-07-2015, 10:04 AM | #5 | ||
| Re: Ascender Aluminum Rock Sliders Quote:
A pair of 2200mah or less lipos should fit nicely. | ||
07-07-2015, 11:34 AM | #6 |
I was thinking dual 5200mah for my sides
07-07-2015, 03:36 PM | #7 |
| Re: Ascender Aluminum Rock Sliders That's a lot of weight and tends to adversely affect the crawling imo. @StillSmokin875, forgot to say that those sliders came out really clean including your attachment points. The more I look at them, the more I really like them. |
07-07-2015, 06:02 PM | #8 |
I won't be running the 5200 s for crawling. Only for messing around and long trips. I'll be keeping the shorties around for when im crawling
Ascender Aluminum Rock Sliders - Similar Threads | ||||
New SSD Side Sliders for Ascender Blazer | SSD | Vaterra Ascender | 21 | 05-25-2015 08:21 PM |
Need Custom Aluminum or Steel Bumpers and Sliders! | alexchen86 | Axial SCX-10 | 11 | 08-20-2012 10:27 AM |
No aluminum Maxx sliders? :( | MacMan | General Crawlers | 15 | 06-13-2004 07:18 PM |
