09-18-2016, 08:30 PM | #41 | |
| Re: Jato The Ascender Quote:
I live far from Pittsburgh. I'm actually only about an hour from Philly or else I'd show you my spots. Thank you! Sent from my SM-N910V using Tapatalk | |
09-19-2016, 10:03 AM | #42 |
Very nice battery tray "meat stick" mod! If you mount it under, you could countersink the plastic tray so that the smooth screw head is next to the battery. |
09-19-2016, 10:27 AM | #43 |
| Re: Jato The Ascender Thanks. That's true. I'm just not sure if the battery tray plastic is thick enough to swallow the entire head of the screw. Definitely something to think about.
09-19-2016, 10:52 AM | #44 |
Maybe use several smaller countersunk screws, 2mm or 3mm because the heads will be thinner. Edit: Or encase it in styrene box lid that can be screwed underneath through the sides? |
09-19-2016, 01:13 PM | #45 | |
I know I've seen a substantial improvement in performance with the addition of the meat stick. | |
09-19-2016, 10:54 PM | #46 |
Rock Crawler Join Date: Apr 2008 Location: pittsburgh
Looking at the bottom of the tray, the supports on the bottom would have to be removed. Not very worth it I'd say. But.... Look closely at those supports... There is a rectangular area in the center about 3/8" below your meat stick where you could glue in a sizeable "chunk-0_meat" to add a bit more weight onto the front axle....
10-14-2016, 08:23 AM | #47 |
My Ascender is getting CODYBOY weighted axle housings. So I'm also doing a "rebuild" of the axles. I am using Fast Eddy bearings. They have always served me well and are reasonably priced. Shipping is pretty fast too. I'm also trying marine grease for the first time. When I opened the old housings the bearings were extremely rusty. My SCX10 bearings never seemed to get that rusty so I'm not sure if the Ascender housings don't seal as well as the Axial SCX10's. The weight of the stock axle housing is 0.95 ounces compared to the CODYBOY axle housing which is 3 ounces. This should help keep the truck a little more planted which will counteract the big, Blazer body on top. |
10-15-2016, 10:35 PM | #48 |
Here's the finished rear axle. It looks good. I'm going to have to paint or even put black tape over the brass though. Rear CODYBOY axle installed with the SSD titanium links. I really hope these links hold up. Stock front links. These are also pretzeled. I just can't get over how badly these links bent with little effort. Stock front axle housing weight vs CODYBOY front axle housing weight. Again, a nice addition of weight. Completed front axle. Front CODYBOY axle installed with SSD titanium links. Again, I need to paint or tape the brass. I finished this up around midnight because I want to take it on a trail run tomorrow morning. To those that suggested putting my Meat Stick on the bottom of the battery tray, this would take an awful amount of work to cut the brass plate or cut off the plastic support webs. |
10-16-2016, 07:46 AM | #49 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
10-16-2016, 02:39 PM | #50 |
My Ascender is dialed now. It easily out performed anything on the trail today. It made easy work of hills that even an SCX10 II struggled on. |
10-16-2016, 11:19 PM | #51 |
Lookin good The side mirrors on the brown blazer... Would they be in scale on the vaterra body? They look killer. |
10-17-2016, 02:16 PM | #52 | |
I don't use mirrors though because they wouldn't even last one trail run with the way I drive. I treat my RCs like they owe me money. Last edited by JatoTheRipper; 10-17-2016 at 02:19 PM. | |
10-17-2016, 04:11 PM | #53 |
Rock Stacker Join Date: Jul 2015 Location: Terry
Those are the same mirrors that would be on a squarebody. Sent from my iPhone using Tapatalk |
10-17-2016, 09:44 PM | #54 |
They sure look like the 85 mirrors I see in pics. I figure I can make them fold when rubbing stuff
10-18-2016, 08:31 AM | #55 |
I thought one of the older gen Blazers had mirrors with the 3 legs/tri-mount? Maybe that was older. I don't know. But anybody except the absolute snobbiest of scale snobs will probably be happy with the RC4WD Blazer mirrors on the Vaterra Blazer body.
10-18-2016, 09:12 PM | #56 | |
As far as half tons go I'm pretty sure they all have the depicted mirrors above. All squarebody a I've seen in person including the two we have have those mirrors. 85&87 Silverado. This is the first I've seen the tri leg ones. Maybe rc4wd has the wrong ones ? Sent from my iPhone using Tapatalk | |
10-19-2016, 06:00 AM | #57 | |
10-19-2016, 11:31 AM | #58 |
What I am wondering is did they only come on the single headlight trucks like the pic I posted? I've never seen the tri pod ones on the 85-88 bodies Sent from my iPhone using Tapatalk |
11-13-2016, 01:29 PM | #59 |
We went on a long trail run today. My Ascender continues to surpass my expectations and the performance is down right impressive. I think the tires are the only thing holding it back at this point. I'd like a stickier compound. I hope Pitbull decides to release the Rock Beasts in the new compound used in the Rock Beast XLs. The HobbyWing ESC seems to be failing. There's a severe stutter in reverse. Time to replace it. I'll probably use the new HobbyWing WP1080 I just received. |
11-13-2016, 02:20 PM | #60 | |
Ernie | |
Jato The Ascender - Similar Threads | ||||
My Ascender Built, One Bad ascender | CustomCrawlRCMike | Vaterra Ascender | 3 | 07-03-2015 03:45 PM |
E-JATO Help please | djjerbeck | Non Crawler RC's | 0 | 03-29-2014 12:36 AM |
Anyone got a Jato 3.3? | XJkid93 | Non Crawler RC's | 1 | 06-29-2013 09:16 PM |
