Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Ascender
Thread: UPDATED 3/2020: Bronco RTR stretch to WB4 servo question
Old 02-09-2019, 09:09 PM   #1
Default UPDATED 3/2020: Bronco RTR stretch to WB4 servo question
Hi Guys. Dusting off my early Bronco RTR. Going to mod it to take a proline C10 body.
Already read all the threads on stretching to WB4. Bought the spacers and the longer threaded rods etc.
Question: will I be forced to change my servo mounting to front to back when I go to WB4? Or can I leave it as is (mounted across chassis)?
I’d rather leave it as is just to keep this change simple. Hoping I don’t need to wait for any new steering linkage parts to get this done.
1esotericguy is offline   Reply With Quote
Old 02-09-2019, 09:14 PM   #2
Default Re: Bronco RTR stretch to WB4 servo question
Servo positioning was different in the shorter wheel based versions so the floating battery tray had clearance. I run 2 K5's, one front to back and the other side to side with no noticable difference.
Sent from my SM-G960U using Tapatalk
Ascender'nMN84 is offline   Reply With Quote
Old 02-10-2019, 01:54 AM   #3
Default Bronco RTR stretch to WB4 servo question
OP here. Thanks. Just finished doing it.
Learned two things maybe not mentioned in the thread yet:
A. For RTR WB1 to WB4 = the rear drive shaft will be too short when complete. For the RTR Bronco, I got the short/short driveshaft setup from the factory. Need to order the short/long replacement set. VTR232079.
B. Never noticed, but my rear upper links were 61mm from the factory. Pretty funny. Wrong all this time. All 4 links are supposed to be 66mm in the rear and my uppers were not. This is on a really early Bronco RTR. Here’s a pic of the four links laid out after removal:
Old 02-10-2019, 04:28 AM   #4
Very good points. Here is a pretty clear explanation of link lengths for the different wheel bases.
Good point on the driveshaft comment as that is definitely going to need to be addressed.
Old 02-10-2019, 10:41 AM   #5
Here’s some pics for reference if anyone else is wondering about this Bronco RTR to WB4 change. That’s the stock RTR body on the now stretched WB4 chassis:
Old 03-25-2020, 01:59 PM   #6
Default Re: UPDATED 3/2020: Bronco RTR stretch to WB4 servo question
OP here. Updating this in March of 2020.
It took a global pandemic, but I finally painted this body. I used liquid mask for the first time. I like this stuff, but it’s pretty space constrained in this shell. In retrospect, I needed a short and stubby xacto handle to pull these lines. Normal handle didn’t fit, so my lines are pretty bad. Fun body though.
Old 03-26-2020, 11:16 AM   #7
Natedog's Avatar
Looking good in red/white, love the older bodies!
Old 03-26-2020, 07:15 PM   #8
Nice day to drop in some real wood paneling in the bed:
Old 03-27-2020, 08:33 PM   #9
Added some lacquer to the boards
UPDATED 3/2020: Bronco RTR stretch to WB4 servo question - Similar Threads
Extending the wb4 wheelbase? Junkk5 Vaterra Ascender 6 03-18-2017 07:37 PM
K5 RTR servo bearinng upgrade question willygee Vaterra Ascender 4 03-03-2017 03:09 PM
Defective RTR, and Servo Question blooton Axial Wraith 1 12-05-2011 02:45 PM
Stretch WB = relocating steering servo? RC_Feen HPI Wheely King 18 06-08-2007 08:39 AM
PTI MMT Stretch Question... phantom309 General Crawlers 18 11-08-2005 06:53 AM
