Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: LED lights in the stock light housings
Old 02-12-2013, 09:51 AM   #1
Default LED lights in the stock light housings
Hello
i want to keep the stock light housings (4 on top, 2 in front) and put LEDs behind them.
i was going to pick up one of these kits to hold the lights, then drilling holes in the stock panels Amazon.com: RPM Roof Mount Light Bar Set, Chrome: SLH RPM80923: Toys & Games
my question is, what LED electronics should i buy? this would be for powering 6 white LEDs.
thanks!
SubyJeff is offline   Reply With Quote
Old 02-12-2013, 10:21 AM   #2
Default Re: LED lights in the stock light housings
It is a lot of work because the cage is in the way. This is what i have so far i used a integy kit with axial light covers.
turboed13b is offline   Reply With Quote
Old 02-12-2013, 10:28 AM   #3
i wanted to get the axial light bar set, but the set is only 5 lights and the twin hammers has 6
was also looking at this light bar set Amazon.com: Pro-Line HID Crawler/Desert Truck Light Bar Kit: Toys & Games
but i need to know what LED / electronics to get
like this ? http://www.rpphobby.com/product_p/rcl106.htm
Old 02-12-2013, 11:16 AM   #4
I was going to use the axial simple light kit and just replace the 2 red leds with a couple of whites ones that I didn't use in another build. It just plugs into the receiver. I have a bunch of axial light buckets and lenses and was hoping that those would fit into the holes in the body. Guess we'll find out when I get mine (hopefully this week!!)
jkwrangler08 is offline   Reply With Quote
Old 02-12-2013, 11:27 AM   #5
You can't run two separate sets of white lights on the simple controller, but you can cut and solder a set of 4 and a set of 2 and use the one plug. That leaves a plug for red. The white/clear lights and reds run on different voltages... Learned this with my Exo.
Mnocton is offline   Reply With Quote
Old 02-12-2013, 01:40 PM   #6
Good info. I did not know that. I have the pieces to do what you're talking about though.
LED lights in the stock light housings - Similar Threads
Light Bar for 5mm LED Lights?? Gimpdiggity Axial SCX-10 6 09-11-2012 04:37 AM
13 LED Light Bar IN STOCK Gear Head RC Vendors Electronics 0 09-28-2011 12:35 AM
SCX10 TR - how to control stock led lights controller via 4CH TX Le0Heart Axial SCX-10 9 01-13-2011 08:03 PM
3Racing LED Light systems in stock RPP Hobby RPP Hobby 0 01-27-2010 05:27 PM
