03-17-2013, 04:56 PM | #1 |
Newbie Join Date: Aug 2011 Location: United Kingdom
| Spur gear upgrade
Hi all i read somewhere that there was a upgrade you could do to go up to 32 pitch spur but now i just cant find it .. So i thought to make life easy i'd start a thread on just this ..What i thought was guys could help other's out and post up what there using (part numbers ) along with what pinion and what motor KV there using and lipo cells .. So if any one can add this will be brilliant .. I found a AS7955 spur fits which is 54t but have no clue on a pinion for it to go with was going to run a 3500kv velineon motor and esc and a v2 slipper pad running 2s so any help on this would be great |
03-17-2013, 06:36 PM | #2 |
Quarry Creeper Join Date: Jan 2010 Location: Lunenburg
The Losi 3907 is a direct fit 51t 32 pitch spur. Currently I'm running a Traxxas 52t spur with a 16t pinion. The Traxxas spur is NOT a direct fit and must be modded. The Losi is a much easier option. Running a 3300kv Pro4 on 2200mah 60c 3s batteries. |
03-18-2013, 03:46 AM | #3 |
Quarry Creeper Join Date: Nov 2005 Location: Italy
| Re: Spur gear upgrade
Looking for a bigger spur to lower the ratio, I've seen this Losi 82T 48P Kevlar spur gear. Based on the comments above about Losi compatibility, I'd guess this one should be a direct fit. Anyone daring to try? Losi: 82T 48P Kevlar Spur: XXX/T: Losi (LOSA3983) |
05-01-2013, 09:35 PM | #4 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
ttt.. Anyone know the largest 32p spur that will fit under the cover? |
05-06-2013, 09:46 PM | #5 | |
Pebble Pounder Join Date: Feb 2013 Location: Near Aurora
| Re: Spur gear upgrade Quote:
05-06-2013, 10:04 PM | #6 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
I just put a 90 tooth on with no issues, but I don't run the cover.
Spur gear upgrade - Similar Threads | ||||
Which pinion gear works best with RC4WD Steel spur gear? | e32lover | HPI Wheely King | 8 | 03-10-2013 06:09 PM |
Which spur gear and pinion gear with 35t motor | vegas1973 | General Crawlers | 1 | 08-19-2012 11:42 AM |
SCx 10 spur upgrade? | 17dean | Axial SCX-10 | 11 | 10-16-2011 01:19 PM |
Rs10 plastic Spur gear seal set upgrade? | Macmanthizz | Redcat Crawlers | 24 | 08-20-2011 11:16 AM |
Wobbling spur gear....Need alum. gear hub! | sickfab | HPI Wheely King | 26 | 10-01-2007 02:09 AM |
