07-23-2013, 06:38 PM | #1 |
Quarry Creeper Join Date: Mar 2010 Location: canada
| best shift servo
dosent need to be waterproof. any thought? ive trashed the stock one and a mini traxxas pos. going to lhs tommoro, could use some advise. i dont need the best just something that wont explode on me. |
07-23-2013, 06:49 PM | #2 |
Quarry Creeper Join Date: Jan 2010 Location: Lunenburg
My Hitec 225 has been working fine for a long time. I got the one with plastic gears. No issues and I believe it was around $18. Pick up a servo saver while your at the LHS. |
07-24-2013, 06:15 AM | #3 |
Quarry Creeper Join Date: Dec 2009 Location: aurora
I agree with Hobine, my 225 has been working flawless for 6 months now. Any servo will work perfect for a shift servo as long as your end points are set properly and of course you shift while moving or at least rotating Sent from my DROID RAZR HD using Tapatalk 2 |
07-24-2013, 10:27 AM | #4 |
Pebble Pounder Join Date: Sep 2012 Location: Richmond
| Re: best shift servo
Agreed. I've been plagued by the infamous shift servo failure. Rather then continue to possibly burn out future factory units, I decided to use a hitec hs-225bb mighty mini, not water proof but strong and durable for little pocket change! So far with epas set its been working great. I did have to convert the shift arm since the mini has a different tooth count than the factory one, so that is something to consider. Hope this helps! |
07-24-2013, 02:49 PM | #5 |
Pebble Pounder Join Date: Sep 2012 Location: Netherlands
I burned out both the stock shift servo and a hitec 225BB after a few packs each. I've run through 15 packs now without problems after greasing the transmission and putting in a full size servo, the grease helped the most. I used a traxxas 2075 servo. It's Cheap, waterproof, and it has plenty of torque for the job. It's mounted a SCX10 servo plate to mount with with one extra hole. |
best shift servo - Similar Threads | ||||
Shift servo brown out? | Antisimplistic | Electronics | 2 | 03-17-2013 07:03 PM |
Shift servo question... | msd44 | Vaterra Twin Hammers | 20 | 03-01-2013 03:41 PM |
Shift servo? | 09 Screw | Electronics | 5 | 03-01-2011 07:12 PM |
shift servo | 4-linkedWK | Electronics | 3 | 04-12-2008 09:06 PM |
