Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: rob_b hits the trails
Old 05-02-2014, 03:37 PM   #221
Pockets70's Avatar
Default Re: rob_b hits the trails
Not needed... but DAAAAAYYYUUUUUMMMM! You're a CNC genius Rob!
Pockets70 is offline   Reply With Quote
Old 05-02-2014, 04:39 PM   #222
Originally Posted by rob_b View Post
Replaced the offset turn buckle that comes with IRIE's steering with a 1pc 7075 that uses bearings.
I like it thats prurdy
Sr.Irie is offline   Reply With Quote
Old 05-05-2014, 08:11 AM   #223
2013 2.2P Nat. Champion
SkaldidDog's Avatar
I had not seen these pics prior to you handing me that part Rob. Now it makes sense. Really nice work (damn CNC guys grumblegrumblegrumble). Thanks a ton for making the long drive up to the comp to hang out. It was great to see you. Hope to cross paths soon again. Thanks for motivating me to complete my steering prior to the comp.
J
SkaldidDog is offline   Reply With Quote
Old 05-12-2014, 04:26 PM   #224
I think the spare tire cage mods are "done" now. Added two verticals to keep the tire from sliding forward. Also made some small threaded 7075 stubs to key into the tread a little better than the screw and nut were alone. I might need to get my vendor star back and offer this as a kit.
rob_b is offline   Reply With Quote
Old 05-13-2014, 07:51 AM   #225
SkaldidDog's Avatar
That's some sexy Al cage-work.
J
Old 05-13-2014, 10:31 AM   #226
Wow! Nice parts and nice truck!!!
tomster is offline   Reply With Quote
Old 06-28-2014, 08:56 AM   #227
Eliminated the slipper spring to gain room for a battery. Both are hardened 4130. Might be cooler to make a one piece version though.
Old 06-28-2014, 09:10 AM   #228
How does this yield more space? looks very similar in length (to my memory which is maybe, well... Ha)
photon_trap is offline   Reply With Quote
Old 06-28-2014, 09:14 AM   #229
That is with an unmodified shaft. Just put it in the truck and decided it would be worth it to shorten the shaft as well. Probably just use the washer... oh well!
Old 06-28-2014, 09:33 AM   #230
I have learned to like my slippers, not sure I'd wanna give it up
Old 06-28-2014, 02:25 PM   #231
Cut the shaft and lost the spacer...
Old 07-19-2015, 03:40 PM   #232
So.................
What now?
travis c. is offline   Reply With Quote
Old 07-21-2015, 07:51 AM   #233
Nothing
Old 07-21-2015, 08:10 AM   #234
You want to trade it for some magic beans?
Old 09-19-2015, 03:48 PM   #235
This is some of the cleanest fab and CNC work I I have ever seen on a TH! Hope this build isn't gone for good.
89redranger is offline   Reply With Quote
Old 09-19-2015, 04:41 PM   #236
It was recently packed deep into storage. It is a shame.
Old 01-03-2016, 06:49 AM   #237
And it's continued...
Sometimes failure can be a good thing. A failed print gave me an idea and that idea turned into some new panels for the Twin Hammers.
I used three different fiber patterns to hopefully maximize the strength of the panels. They have 4 solid layers of Nylon and 1-2 solid layers of Kevlar. Thickness ranges from .020"-.024" respectively. The only finishing work required is to drill the holes. They are basically indestructible by hand but need some testing in the real world to see if they hold up.
The hood...
Unidirectional layout
The side panels...
Still unidirectional but @ 45*
The roof...
2 ply isotropic layout @ 45* and 135*
Takes two printings totalling 6.5 hours
In process...
And finally installed.
Old 01-03-2016, 12:18 PM   #238
Can they be printed slightly oversized and then trimmed for a nice clean edge? How do they take paint?
Either way, excited to see life here. Sick build with a lot of wicked ideas. Will be subscribing.
Old 01-03-2016, 12:23 PM   #239
They could be printed oversized or even just as a rectangular sheets and then cut with the cnc router.
rob_b hits the trails - Similar Threads
Toyota Blizzard hits the trails! pardonmyn00b Scale Videos! 4 07-25-2012 05:34 AM
Imthatguy's 'Yota hits the trails. imthatguy Videos! 23 11-13-2011 12:03 AM
