Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Sourdough Twin Hammers
Old 03-26-2014, 12:15 PM   #1
Default Sourdough Twin Hammers
Well since I suck and building trucks from scratch, I picked up this roller yesterday for a hundred bucks. It needs a lot of cleaning and lots of TLC, but I have some pretty neat ideas for it, so stay tuned!!!
sourdojack is offline   Reply With Quote
Old 03-26-2014, 12:32 PM   #2
Pockets70's Avatar
Default Re: Sourdough Twin Hammers
Can't go wrong at that price! What's needed?
Pockets70 is offline   Reply With Quote
Old 03-26-2014, 01:34 PM   #3
It's all there minus electronics, which is perfect cause I already have most of the electronics sitting on a shelf.
It's bone stock and missing a few misc pieces. But I am going to go through it and upgrade parts as I go
Old 03-26-2014, 01:45 PM   #4
Any particular ideas you have in mind?
Silver Fox is offline   Reply With Quote
Old 03-26-2014, 01:58 PM   #5
Starting with the front:
Bolt on a bell crank
Make a carbon fiber shock mount (maybe put GTR shocks on it)
Make new links out of carbon fiber tube or 7075 aluminum
Bolt on VP knuckles
In the rear:
Make lower links out of Delrin about 20mm longer than stock
Make new upper links out of carbon fiber tube or 7075 aluminum
Maybe put Big Bores on it
Bolt on a sway bar
That is about it off the top of my head... I wanna get it running soon so I can enjoy it this summer! I'm going to get a list of parts I need and get it ordered next week
Old 03-26-2014, 02:40 PM   #6
Don't forget some 500K diff lube in the front diff. Possibly a new steering servo and assembly as the stocker is pretty weak and the stock set up is sloppy. I also think you should check for stripped screws, the version I picked up off of Ebay had about 25% of the screws stripped out or missing. A stainless screw set (which didn't include ALL of the screws necessary) cost me all of 20 bucks, but it was definitely worth it.
MeanTT is offline   Reply With Quote
Old 03-26-2014, 02:50 PM   #7
Thanks for the tips
I will most likely run a spool in the front... Not 100% sure yet, when I take it apart to clean & grease it I will figure it out.
It didn't come with a servo, but it is going to be getting a hitec 7950 and bell crank to replace the stock set up.
I am going to put all 3mm stainless/aluminum hardware on when I go through it as well
Old 03-26-2014, 05:28 PM   #8
Don't forget to check the set screws for the drive shafts front and rear to make sure they are loctited. Can't wait to see how it goes with this build
kookie31 is offline   Reply With Quote
Old 03-26-2014, 05:37 PM   #9
Yup, my front set screw came loose after 2 days of owning it.
Sent from my Nexus 5 using Tapatalk
Old 03-26-2014, 09:21 PM   #10
Yeah I hate it when drive shafts come loose. The Losi Comp Crawler I had was really bad with that!
I'm going to put on a SDI4x4 rear drive shaft. And every screw that goes into steel or aluminum is getting loctite
Old 03-26-2014, 10:46 PM   #11
Are you going to make your own bell crank or get one from a vendor? Good to see that you got your own rolling now Tom instead of stealing Wil's.
Fingonunny is offline   Reply With Quote
Old 03-26-2014, 11:20 PM   #12
I'm going to buy a bell crank with ball bearings and mount it up somehow. Shouldn't be too hard. And yeah I loved driving Will's TH at the G6, had to get my own!
Old 03-28-2014, 02:48 PM   #13
Well I tinkered on this a little bit last night. Just kinda looked it over and tried to envision what direction I want to go with it. I decided I am not going to build a hard core "scale" rig. I want it to perform great first, then have a scale appearance second.
I don't really know the scale rules for competition... I am mainly building this as a U4RC/G6/Basher
One of the first things I did was start switching out the nylocks for anodized black aluminum ones from fastener express
Next I made shift linkage for the trans. I used black aluminum hardware, light weight rod ends from a GC3A kit, 3x30mm Ti screw and springs from a Bic pen. I wanted to keep the weight down so the servo has less work. Sorry for the blurry picture, but you get the point...
Then I cut up some 2mm carbon scrap and roughed out a battery tray
Threw on some garbage wheels and tires for a quick mock up. I think I will be ordering VP Method wheels and Pitbull tires...
Old 03-28-2014, 06:24 PM   #14
Pockets70's Avatar
I wouldn't mind taking those Two Faces off ya.
Old 03-28-2014, 11:32 PM   #15
Sure, but there is only 3 of em really... I cut the beads off of one to try it on a 2.2
Old 03-29-2014, 01:06 PM   #16
CODYBOY's Avatar
My Twin Hammer up grades. Sorry, I haven't figured out how to copy and paste a build thread!
Here is a build I have been working on for a while. I did the bell crank up grade, but have not post pics.
CODYBOY is offline   Reply With Quote
Old 04-03-2014, 11:18 PM   #17
Got a heart and soul for the Twinzy today!
Also did the "green spring" mod to the front shocks
Old 04-07-2014, 08:40 PM   #18
Size:  65.1 KBName:  uploadfromtaptalk1396924741507.jpg
Size:  52.7 KBName:  uploadfromtaptalk1396924760153.jpg
Size:  41.0 KBName:  uploadfromtaptalk1396924776153.jpg
What do you guys think about running some of these sweet new 2.2's?
They fit great mounted to .225" hubs!
Old 04-07-2014, 08:45 PM   #19
666
MODERHATER™
666's Avatar
Tutus are a bit much on a TH, they get into the chassis/body when turning, hard on the front axles.
666 is offline   Reply With Quote
Old 04-08-2014, 11:55 AM   #20
Pockets70's Avatar
With the right offset, they'll work. Just be careful with tire rub
Sourdough Twin Hammers - Similar Threads
My Twin...Twin Hammers build start sanny632 Vaterra Twin Hammers 8 03-09-2014 12:01 PM
Savage00's Twinny Twin Twin Hammers Savage00 Vaterra Twin Hammers 16 09-19-2013 08:09 PM
my new twin hammers neon9 Vaterra Twin Hammers 3 09-07-2013 07:05 PM
Twin Hammers xCoolHandLukex Formula Offroad 15 05-11-2013 09:51 PM
Twin Hammers in Twin Cities? 89XJ Minnesota 7 05-06-2013 02:59 PM
