Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Mongo's Twin Hammers
Old 04-08-2014, 11:32 AM   #1
Default Mongo's Twin Hammers
I picked my Twin Hammers up off ebay. She came with a GCM shock tower (a thing of machined beauty) installed along with Axial front shocks. The front has a locker installed as well. Everything else is completely stock. Here is how she arrived at my front door.
Mongo is offline   Reply With Quote
Old 04-08-2014, 11:36 AM   #2
Default Re: Mongo's Twin Hammers
After a few runs out in the backyard and driveway, I realized this is gonna be a fun car, but it needs some work. Steering was horrible, the stock servo has got to go. I'm still trying to decide if I want to keep the locker in it. Torque twist on this thing is insane. Gotta install a rear sway bar.
Old 04-08-2014, 04:36 PM   #3
Check out the GCM rear piece. It helps a TON on the twist.
Beej is offline   Reply With Quote
Old 04-08-2014, 05:26 PM   #4
Yeah I thought about picking the GCM rear piece up but gonna try a sway bar. Lot cheaper.
Sent from my XT1080 using Tapatalk
Old 04-08-2014, 09:35 PM   #5
The sway bar will make a big difference and removing the spare tire helps as well.
Sr.Irie is offline   Reply With Quote
Old 04-09-2014, 08:07 AM   #6
Spare tire will probably stay where it is for now. I really like the scale aspect of it.
Old 04-09-2014, 08:10 AM   #7
HiTec 646WP installed. Should be sufficient for my needs. Had to grind down the servo horn to clear the shock mounts.
Old 04-09-2014, 08:13 AM   #8
Decided to keep the stock body panels for now and spend money elsewhere, so I stripped off all the decals.
Old 04-10-2014, 08:10 AM   #9
Rear sway bar installed. Went with the medium weight bar to start out.
Old 04-12-2014, 08:08 AM   #10
Pro-Line TSL Super Swampers mounted on Axial rims.
Old 04-14-2014, 10:44 AM   #11
Done for now, raided my decal box and threw on some decals. Ready for the rocks.
Old 04-15-2014, 10:06 AM   #12
Poser shots........
Old 04-15-2014, 10:11 AM   #13
........and first time on the trail.
Old 04-15-2014, 11:17 AM   #14
did you drive yours much before the sway bar install ? im curious how much better or worse it made it handle while crawling.
Rig looks great ! I Love those tires !
Mollett89 is offline   Reply With Quote
Old 04-15-2014, 11:51 AM   #15
I drove it around in my backyard without the sway bar but never crawled with it. The sway bar did make a massive difference reducing torque twist. I can't imagine crawling without it. Uphill climbs would be a nightmare. Definite must have. And thanks for the compliments. I think the rig looks great with the TSL's.
Old 04-15-2014, 06:23 PM   #16
I was very impressed with the crawling capability of this rig. It walked up lines that I had trouble with with my other rigs. I think I may just leave the locker in it, I had planned on running 50k fluid but loved how it worked out on the rocks. I do need to internally limit the front shocks a little bit, I popped the front dogbone out a couple of times.
Old 04-15-2014, 06:25 PM   #17
As much as I like the TSL's I do wish they were a bit taller. I think the XL's would look too big. What tires are you guys having good luck with on the Hammers?
Old 04-15-2014, 08:33 PM   #18
It looks awesome. I'm thinking about picking up a Twin Hammers as my next project.
captainmorgan is offline   Reply With Quote
Mongo's Twin Hammers - Similar Threads
My Twin...Twin Hammers build start sanny632 Vaterra Twin Hammers 8 03-09-2014 12:01 PM
Savage00's Twinny Twin Twin Hammers Savage00 Vaterra Twin Hammers 16 09-19-2013 08:09 PM
Twin Hammers in Twin Cities? 89XJ Minnesota 7 05-06-2013 02:59 PM
ae-2 into twin hammers help kakachille Vaterra Twin Hammers 15 03-12-2013 06:06 PM
