![]() | #1 |
RCC Addict ![]() Join Date: May 2008 Location: Southern,WV
| ![]() So I was fed up with the torque twist on my TH. I looked at other ways to help with it.And what I could buy to help. So to me it seemed that from what I found. If the top links are up a little more it helps with the twist. So I came up with a way to not only raise them up but to do it cheap. And it looks kind of cool too...lol Here's what ya need. Eight Axial steering kingpins, four 3/4" m3 screws. That's it.. ![]() With the kingpins stacked up you get the lift you need. ![]() So take out the screws holding the top link mounts and lift them up. Then stack two of the kingpins on top of one another. With the little ends in the middle (as shown) then just put the longer 3/4" screw in the place of the short ones you removed.And after you do both ends on both mounting brackets you get this. ![]() ![]() |
![]() | #2 |
Rock Crawler Join Date: Oct 2010 Location: Reno
Very nice tiny. Thanks for the cheap upgrade idea!
![]() | #3 |
| ![]() No problem... I'm going to get some silver metal ones so they stand out a bit and match some of the metal upgrades I'm going to order...lol ![]() |
![]() | #4 |
I found where the silver kingpins came from...They came on a Duratrax cliff climber...So I found my old set of axles and robbed them of their pins....lol I'll just replace them with plastic ones.I also put in longer screws. Maybe 7/8 of an inch long..Here's the update pics... ![]() ![]() ![]() ![]() |
![]() | #5 |
Quarry Creeper Join Date: Dec 2012 Location: SoCal
good thinking dude!
![]() | #6 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
Another installment of...TINY's TIPS c'mon man you gotta do it! It'll be a sticky And if you're wondering, no, I haven't built anything yet lol. Still debating about learning how to braze.
![]() | #7 |
![]() | #8 |
Rock Stacker Join Date: Feb 2013 Location: Dayton
Add a sway bar it helps a lot.
![]() | #9 |
![]() | #10 |
Rock Crawler Join Date: Dec 2013 Location: Tuxedo NY
The lightest sway bar really helps! Kinda actually even helps crawling too!
Mad torque build, cheap and easy | Nimyad | Superclass Crawlers | 160 | 01-31-2016 08:02 PM |
Torque twist | s14slide | Venom Creeper | 6 | 12-14-2009 03:13 AM |
Torque Twist Q | Brandon13 | Axial AX-10 Scorpion | 1 | 07-04-2009 04:32 PM |
Torque Twist? | Mini | Newbie General | 3 | 12-13-2008 10:19 PM |
Cheap mod for axle steer/torque twist | Oze30 | Axial AX-10 Scorpion | 5 | 03-03-2008 05:28 PM |
