Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: What do I need to make the wheel base longer? Do yeti or smt10 links work?
Old 08-01-2017, 01:10 PM   #1
Default What do I need to make the wheel base longer? Do yeti or smt10 links work?
Any suggestions?
Thickone is offline   Reply With Quote
Old 08-01-2017, 05:22 PM   #2
Default Re: What do I need to make the wheel base longer? Do yeti or smt10 links work?
Yeti links work. I've fitted them to my TH before with no issue.
Rotare is offline   Reply With Quote
Old 08-02-2017, 06:17 PM   #3
Now for the drive shaft I'm going with mip shaft for the yeti. Any other recommendation?
Old 08-02-2017, 09:35 PM   #4
I'm using the MIP Yeti driveshaft with Yeti length TA's...it's a match made in RC heaven! Do it!!!!
bilinvic is offline   Reply With Quote
Old 08-03-2017, 07:32 AM   #5
Is it a direct bolt up or do I have to grind the ends off?
TY
Old 08-03-2017, 07:49 AM   #6
Yes, I forgot to mention that, I had to use my Dremel to remove about .5mm of material in order for the grub screws to match up with the flat surfaces on the outputs.
Old 08-04-2017, 12:00 PM   #7
Thanks bud.
Old 08-22-2017, 04:40 PM   #8
Update up and running
Yeti rear links mip drive shafts
Old 08-22-2017, 05:35 PM   #9
Looks good. What upper libks did you end up using?
nedmo is offline   Reply With Quote
What do I need to make the wheel base longer? Do yeti or smt10 links work? - Similar Threads
Longer wheel base byrnieman Axial SCX-10 10 03-31-2015 01:16 AM
Dingo longer wheel base Bogncrawl Newbie General 5 09-25-2012 11:10 PM
Longer wheel base. Mr.JayDeeM Axial AX-10 Scorpion 7 06-28-2012 04:22 AM
longer wheel base Losi man Losi Mini-Rock Crawler 2 09-07-2009 08:07 AM
4wd wk Wheel base longer Troublemaker HPI Wheely King 15 05-23-2007 01:13 PM
