Go Back   RCCrawler Forums > Vendors > Vendors Market > Vendors Electronics
Thread: Heyok: Rock Lights on a budget
Old 12-04-2015, 11:40 AM   #1
Lightbulb Heyok: Rock Lights on a budget
EDIT:Now available for 2S lipo power too!
Light up the ground under your crawler to help you choose the right line!
These rock lights are made from sealed LED strips that will run from 3S power (~12 volts).
A light controller lets you operate the rock lights with a two position channel.
This set up is waterproof!
Attach the lights to your rig with the already applied 3M adhesive. My preference would be to use the original adhesive to get the light positioned where you want, then make sure they stay in place with a bit of Shoo Goo or Goop etc.
This version will operate your your 2S lipo powered rig!
To try and keep this item as affordable as possible, there is some work involved for the installer. Connectors for the lights and power have been omitted.
The wires going to the lights will be 10 to 12 inches long.
Tie all the red wires from the lights together and to the red wire of the light controller. Tie all the black wires from the lights together and to the white wire of the light controller.
Plug the receiver plug into a two position channel.
Make the connection to a 3S battery to the red and black power wires. My suggestion would be to solder them to the battery connector on your ESC.
Part number: RL4S
Price: $30
Part number: RL4S2P
Price: $40
Includes the four light segments with leads and the light controller for a two cell lipo battery.
Last edited by heyok; 03-11-2020 at 11:02 AM. Reason: Added version that will work on 2S lipo
heyok is offline   Reply With Quote
Old 12-04-2015, 05:54 PM   #2
Default Re: Heyok: Rock Lights on a budget
I like it !!!!!!
Can the lights run off 3s without the use of the controller ?
Is it necessary to run 4 lights or can a guy add or omit as needed ?
hotwheels000 is offline   Reply With Quote
Old 12-04-2015, 06:02 PM   #3
Cool! Glad you like it.
I could break it apart. The set of four lights would be $25
Old 12-04-2015, 07:10 PM   #4
Thats great, for folks that dont have an open channel.
How about the other question ? I am wondering if they need to be run in parallel to acheive proper operation without damaging the lights.
Old 12-04-2015, 07:24 PM   #5
The lights are made to run in parallel from a 3S pack or 12 volts. Just use one or two or whatever you need.
Tie all the reds and blacks (I actually think the ones in the picture are brown wires) together. No need to worry about resistors.
Red is positive, black(brown) is negative.
Old 12-05-2015, 10:01 AM   #6
I realize now that the wire lengths on the lights shown in the picture are probably a little short.
From now on, the wires going to the lights will be 10 to 12 inches long.
If someone wants to buy my prototype set of winch lights, you can have them and the light controller too for $20 plus shipping.
Send me a PM if you are interested.
Thanks!
Al
Old 12-05-2015, 02:18 PM   #7
These are awesome! I'll be picking up a few sets for sure!
BadWagon is offline   Reply With Quote
Old 12-05-2015, 03:14 PM   #8
Thanks!
When you are ready, just send me a PM and I will process your order.
Old 12-06-2015, 09:40 AM   #9
Hi I would like to buy your rock light set up I have your winch control.Ihave a futaba pls and
all the plug are in used.Can you call me 309-206-4861.
papafogle is offline   Reply With Quote
Old 12-06-2015, 10:12 AM   #10
I'm not able to phone you right now.
Send me a PM if you would like to place an order.
Thanks,
Al
Old 01-19-2016, 08:27 AM   #11
are these waterproof? thanks!
Old 01-19-2016, 08:33 AM   #12
Yes. You're welcome.
Old 01-19-2016, 09:04 AM   #13
Winning.
Old 05-20-2016, 10:10 AM   #14
The exact type of LEDs will depend on what I have in stock.
This is what the last several Rock Light kits had:
It comes with four light strips. Only two shown in this picture.
Old 09-04-2016, 03:56 PM   #15
Hey! Can you do these with colored LEDs?
Sent from my SM-G900V using Tapatalk
YeeP is offline   Reply With Quote
Old 09-04-2016, 03:58 PM   #16
Maybe. What colour are you after?
Old 09-04-2016, 04:01 PM   #17
I was thinking more of a blue. Green for my son's rc also. Don't want it to look like a low rider but a different color might be fun.
Old 09-04-2016, 04:03 PM   #18
If you are serious, send me a PM and I will see what we can do.
Old 09-05-2016, 01:54 PM   #19
Can you do a controller that does not need to be plugged into the radio? I don't have a spare port.
ynmech is offline   Reply With Quote
Old 09-05-2016, 02:15 PM   #20
You can use one of these:
Add-a-channel
Or I could put in a toggle switch.
Heyok: Rock Lights on a budget - Similar Threads
LED lights on a single HeyOk switch SoCal_80 Axial Wraith 2 01-25-2015 08:24 PM
Newbie to this forum. Rock Crawler, Low Budget Ian78 Chit Chat 5 02-09-2013 08:31 PM
Rock lights anyone? m4rK Traxxas Crawlers 6 09-07-2011 06:07 PM
buiding a rock racer on a budget got some ? canadianjeeper Newbie General 2 02-06-2008 10:54 PM
You may edit your posts
