03-04-2009, 04:30 AM | #101 | |
RCC Addict Join Date: Apr 2008 Location: In The Machine, "Turn the light back ON"
03-04-2009, 05:56 AM | #102 |
Quarry Creeper Join Date: Oct 2008 Location: Jamestown
| Mantis Build heres my build thread H3RESQ I didnt realize that I needed a spacer between the rear links also. That must be why a couple times when it flexed to far it stayed tweaked. |
03-04-2009, 10:05 AM | #103 |
Pebble Pounder Join Date: Mar 2007 Location: Vancouver,BC,Canada
What ever happened to the super version of the Mantis Is it dead |
03-04-2009, 08:07 PM | #104 |
Rock Crawler Join Date: Jul 2006 Location: Olympia
03-04-2009, 08:14 PM | #105 |
Great pictures of your rigs guy's. If you can upgrade the rear links to alum. This will help keep the frame from tweaking. I'd run delrin up front but the rear needs the strength of alum. along with a center spacer. This will keep it from both over flexing and also gives it better side to side support so it won't bend the chassis plates at the link mount area. Try to get your belly of chassis as close to motors as possible, this will allow a smooth transition and allow for better breakover. Ideally the lowers should mount in the hole between the large and medium chassis holes maybe think about a skid like in pictures to. It's also allows a area to mount some of your electronics lower. My speed controls are mounted to top side of skid in picture. This would deffinitially help the CG on your rig Siggy. Last edited by H3RESQ; 03-04-2009 at 08:22 PM. |
03-04-2009, 09:00 PM | #106 | |
Rock Stacker Join Date: May 2008 Location: Miller Park
What thread are the studs that are included? 4mm X ???? | |
03-05-2009, 06:08 AM | #107 |
Thanks for the advice H3. Do you know if those link lengths you gave earlier in this thread did you get to double check on that yet. I am getting a bunch of rod in shortly and am probably going to cut some new links to the correct length. |
03-05-2009, 12:00 PM | #108 |
RCC Addict Join Date: Apr 2008 Location: Singapore
Thanks H3, will try to-out your suggestion. with my present set-up, the 2 ESC's was ontop of the 2250 3s lipo as it was tough finding a spot for the lipo. Maybe I will need to use a smaller Lipo .
03-05-2009, 12:05 PM | #109 |
hey siggy you might want to look into doing what I did and mount it to the rear axle maybe. Only thing that I made sure to do when I did that is put a piece of lexan over it
03-05-2009, 12:29 PM | #110 |
| My 1550 3s fits in there nice but tight. Has been enough for me on 45T mild modified motors.
03-05-2009, 12:32 PM | #111 | |
I would recommend against mounting battery to rear of vehicle(especially the rear axle, these batts are big to run dual motors). You want that weight in the belly for proper balance and sprung weight. Looking at your rig and that batt, could you mount it on the upper links. Basically your electronics are lighter, they should be mounted on links, axle's, etc. battery in belly or front axle is better. Last edited by H3RESQ; 03-05-2009 at 12:35 PM. | |
03-05-2009, 12:39 PM | #112 | |
03-05-2009, 01:13 PM | #113 |
thanks a bunch for the advice H3 I really apreciate it. I will give it a try. I love to wrench on my trucks so I might change up how all the electronics are mounted up I have some Holmes Hobbies dig switches comin in so I was going to change it up a bit anyways. I understand what you are saying about the correct sprung/unsprung weight I just really didnt like the idea of locating my electronics on a gigantic skid plate on those rear links. It just seems.... well....gigantic |
03-05-2009, 10:36 PM | #114 | |
What is your current motor to chassis clearance? | |
03-06-2009, 05:58 AM | #115 |
03-06-2009, 07:59 AM | #116 |
Rock Crawler Join Date: Jul 2005 Location: Phoenixville
210solomon007 sent you an email about my mantis chassis i purchased. thx. joe
03-06-2009, 08:17 AM | #117 |
| Hi H3, Can we got a top shot of your rig. Wanted to see how you did the rear skid and laid the electronics. Thanks! |
03-07-2009, 05:55 PM | #118 | |
Ideally you just run the axle at furthest back location on tail of chassis using supplied rear links(should measure 4 1/2 inch eye to eye on rodend hole). With all factory links it should end up at 12.5 inches and belly up tight to motor... these measurments are assuming that the average person has not torn apart there Bergs and clocked them....and is running bergs EDIT.....Just realized what's going on. The links coming in these kits are not consistent. I just recieved them and the lengths are wrong. Here are really close exact to what you want...This is LENGTHS WITH ROD ENDS>>>EYE TO EYE> REAR LINKS.........4 1/2 inches FRONT UPPERS.....2 3/8 inches FRONT LOWERS.....3 1/2 inches Last edited by H3RESQ; 03-11-2009 at 09:20 AM. Reason: Front Lowers | |
03-07-2009, 06:12 PM | #119 | |
H3. | |
03-07-2009, 06:44 PM | #120 | ||
