01-23-2009, 01:47 PM | #41 |
Pebble Pounder Join Date: Dec 2008 Location: Cen Cal
Sweet mod... But I would not really care if the rear unlocked. I would look into a similar setup for the front. Maybe with a 645 and a cable of some kind.?? Don't know.
02-08-2009, 03:42 PM | #42 |
Rock Crawler Join Date: Feb 2009 Location: On the "ROCKS"
| Broken Shaft Creeper
Just broke the wheel shaft on my new creeper:-(. How long is the wait for replacement parts? Looks like I'm not alone on this problem!
02-08-2009, 06:47 PM | #43 |
Rock Stacker Join Date: Feb 2009 Location: Sunset, Utah
Call venom cs and they will ship it you. I would tell them to go ahead a send all four because you will just break another one and have to wait again (if you got one overheated one then you probly have all four). I live in utah which is next to where venom is in idaho and it take 3-4 days for the shafts to arrive at my door. Talk to Paul ext. 204. The cs there is pretty good though. Hope this helps.
02-08-2009, 08:17 PM | #44 | |
Quarry Creeper Join Date: Dec 2008 Location: Post Falls, ID
02-15-2009, 10:55 AM | #45 |
Newbie Join Date: Jan 2007 Location: canada
hey man I tried to set up a diff locker kinda how you did there, but since I'm a total newb I stripped the gears out of the servo i was using. Do i need to use a servo that can be programmed? I tried a cheap hs-81 micro servo but the throw on the servo arm was too much got any tips? |
02-15-2009, 01:16 PM | #46 |
Sounds to me like you need to turn down the EPA (end point adjustments) on you radio for your servo that is running the locker. It makes it so the servo won't move as far which is causeing it to strip out. Thats my thoughts anyway.
02-15-2009, 01:22 PM | #47 |
Quarry Creeper Join Date: Jun 2008 Location: Ironton
that is sweet!!! i think i will have to do that...
02-15-2009, 07:16 PM | #48 |
thanks I see what my problem is, my crappy radio only has end point adjustment for throttle and steering, the 3rd channel has no adjustments.
