01-25-2010, 07:37 PM | #21 |
Rock Crawler Join Date: Apr 2008 Location: Greentown
Put the motor in now, its a PITA to get in/out when its all assembled. Looks good otherwise. |
01-25-2010, 07:49 PM | #22 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
I hear ya, they recommend you put it in when you start your build, but if you have to change pinion gears or clean and maintain your motor your still screwed |
01-25-2010, 08:20 PM | #23 |
Newbie Join Date: Jan 2010 Location: Deering, NH
| that's how I did it. Not sure how that would have happened. did it right in my kitchen on my stove. Took aluminum foil and lined a metal dish with. weird
01-25-2010, 09:02 PM | #24 |
Pebble Pounder Join Date: Dec 2009 Location: Who Dat Louisiana
Keep up all the pics, kinda lets us relive some of the joy in building ours... |
01-26-2010, 04:24 PM | #25 | |||
Rock Stacker Join Date: Jan 2010 Location: Vacaville
I will keep posting pics. I am enjoying the build and by taking pictures is slowing me down to a nice pace. Weather sucks so I would probably be destroying my creeper right now if it was built. Thanks again for comments and feedback. | |||
01-27-2010, 02:43 AM | #26 |
Pebble Pounder Join Date: Sep 2008 Location: New Zealand
Oh yes we all remember the Venom build. I had numbered bags though so it was not so bad. The motor mount is a bugger but I have had mine a month and had no reason to pull the motor yet. When i do I will post a thead as to how I intend to remedy theis issue if it is an issue for an creeper owners. Long bolts will be the key to it. |
01-27-2010, 02:28 PM | #27 |
| i also just checked and I used the shaws brand oven cleaner. might be different, cheaper chemicals in the one I used, maybe not so potent.
01-27-2010, 03:11 PM | #28 |
Rock Stacker Join Date: Feb 2009 Location: Denver
01-27-2010, 07:30 PM | #29 |
Seating the brushes on a brushed motor. You just hard wire brushed motor to battery of your choice and run it fully submerged. I found that some people run a full c battery or even two C batteries but i found after a little research on brush seating techniques that once you hear a noticeable difference in the rpm speed the brushes should be good to go. Then you clean the motor out with a good motor spray and re oil the bearings/bushings. Its supposed to give a great deal of life to the brushes/motor and good for additional power/torque as well...
01-27-2010, 07:34 PM | #30 |
| Well i forgot to take the picture of the foil and the wife threw it away since it obviously looked like garbage... I did the experiment again since the smoke show was well worht it and it is the Heavy Duty EZ Off brand oven cleaner and aluminum foil crunched up and layered. i guess the reaction between layers and the EZ Off creates a battery like effect and enough heat is generate the foil breaks down and actually burns. the smoke is by product of the foil burning and the low temperatures outside when I did test. |
01-27-2010, 08:55 PM | #31 | |
01-28-2010, 02:45 PM | #32 |
My FLM lockers arrived yesterday so I could continue with build...thank you William at RCBros and Regina at Fast Lane Machine....they look great. Laid everything out to build the rear axle on my creeper along with HR axle lockouts. I finished but forgot to take a finished photo. I ran only one of the Hr shims because with two shims the hex pin hole is sucked very close to the lockout..probably too close... Last edited by smr; 01-28-2010 at 02:50 PM. |
01-28-2010, 02:48 PM | #33 |
| second creeper!!!
on a side note...I started a second creeper kit which was missing a few parts and I started it last night as well (not going to document as it is stock and would look exactly the same as this build ) I had to contact venom and I have to say although I don't have replacement parts yet, Jason replied way faster then I expected and sounds like I should have what I need to finish the second one very soon... |
01-28-2010, 10:16 PM | #34 |
Quarry Creeper Join Date: Jan 2010 Location: north phoenix
for the beadlocker what size screw were you gonna use i think i should do this with mine.... where you gonna drill new holes or re-use the same ones
01-29-2010, 04:27 AM | #35 |
Quarry Creeper Join Date: May 2008 Location: Ontario, Canada
Those HR lockouts are very inconsistant....my brother in law had to use both shims on one side and coould use 3 on the other.....very dissapointed with HR in these.
01-29-2010, 06:38 PM | #36 | ||
02-01-2010, 12:45 PM | #37 |
Well I didnt take as many pictures as I wanted through rest of build as I forgot my camera..here you go... Finished building axles and started assembling everything together.... Axles mounted to chassis...(and yes motor was in before this point.) I installed the Venom remote locker servo kit for front axle...I messed this up good and am going to rectify tonight. I messed the cable up pretty good when I wasn't paying attention. Here is done product...Remote locker isn't working so I tightened up screws on lever until I fix it, its going to run locked... Sorry bad photo with bag blowing into garage right behind truck... with Creeper body installed. |
02-01-2010, 12:54 PM | #38 |
| Test Drive...
So I am running FXR with a Pro 45T motor and a 14T Pinion and a 2S 2000MAH Lipo.... Love it....we have a real hokey test setup in my driveway. it was really challenging for a mini crawler on stock tires but for the creeper it was really boring We changed course(laughable) a little and still haven't set anything up it cant go over...friend finished his LCC with a Goats 3S and 21.5T motor and I crawled all over it and he broke a VCD after about five minutes of crawling same line as Creeper...I'm really happy with it... |
02-01-2010, 01:23 PM | #39 |
Pebble Pounder Join Date: Jan 2010 Location: brooklyn
| Me too!!!
KIND've jealous of the labels !!!! LOL:-(
02-03-2010, 05:23 PM | #40 |
| The labels were great for those of you who didn't have them...you missed out. Made it a lot easier.. Here's some testing pics on the hokey trailer climb we built...the Rovers are prob the best money I spent. The wood is very slick even dry and its pretty wet in the pics and top of trailer has ice on it... for the record our test climb is an old Ikea bed and bed slats leaning on my tent trailer. Its very steep and very slick but for some reason its hours of fun... |
