01-18-2010, 11:43 AM | #1 |
Rock Stacker Join Date: Jan 2010 Location: Vacaville
| nOOb...:) WARNING LARGE PICTURES + LOTS OF FONT
Well since I have been browsing the forums for information for a couple of weeks and have finally started my build I thought I would introduce myself. I'm in Northern California. I'm not new to RC by any means but have just now added crawling to the collection. I purchased a Venom Creeper (red if it matters) and have been sitting on building it for some time. I believe I have gathered everything I need to start but any advice or tips appreciated.. Venom Creeper Set of soft Rovers CKRC stage II suspension CKRC drive shafts Remote lock servo kit for front axle FLM locker for rear (plus an extra in case I don't like the front remote lock setup) Tekin FXR + 45T Tekin Pro MG995 Servo (haven't bought a horn yet) I think thats about it for now...any tips/feedback appreciated. ill post pics once Im done assembling and painting...thanks. Steve I have started my build...I don't have all the parts and accessories I ordered yet but thought I would start the stuff I know I'm not modding right away... I organized my parts and inventoried the entire kit...only thing that appears to be missing is VEN-8314 2 x 6mm SH CAP SCREW. I dont see this actually used anywhere in the instructions. It refers to it on the front axle but it doesn't show anyplace for it. I have some already so no big deal but odd... Got the trans built last night the during build shots weren't in focus so here is finished shots as if no one has seen the trans before It is super tight so I did just like another member here and assembled and ran it with drill for a bit and took apart and cleaned and then reassembled. Still tight but better. Last edited by smr; 01-21-2010 at 06:15 PM. Reason: adding build info |
01-18-2010, 12:57 PM | #2 | |
Newbie Join Date: Dec 2009 Location: earth
Same goes for the diff's set them up correctly and they won't pop out. | |
01-18-2010, 01:56 PM | #3 |
Quarry Creeper Join Date: May 2008 Location: Ontario, Canada
Have a good set of Hex drivers and pre thread the holes using a cap screw rather than trying to get a flat head with a tiny allen key to cut new threads. Patients and some strong wrists will get you through it!!
01-18-2010, 06:47 PM | #4 |
Thanks for the tips...I already have my taps ready to pre thread the holes. I did how ever read even with proper threadlock and cleaning the pins still came out? Maybe they are bashing hard enough to break what ever is in front of them? I will see what happens. Start the build later this week.
01-18-2010, 07:11 PM | #5 |
RCC Addict Join Date: Oct 2009 Location: Nanaimo, BC (Vancouver Island)
I used a dremel and cut some small flat spots in the middle of the cvd pins so that the set screw would sit in it and they aren't going anywhere, I used heatshrink as well just incase.
01-18-2010, 07:23 PM | #6 | |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
01-18-2010, 08:13 PM | #7 |
Rock Stacker Join Date: Nov 2009 Location: Hawaii
Hey welcome on board... Yea take you time and enjoy your build and don't forget to post pics |
01-19-2010, 07:48 AM | #8 | |
Newbie Join Date: Jan 2010 Location: Deering, NH
01-19-2010, 08:08 AM | #9 |
Quarry Creeper Join Date: Dec 2008 Location: Deltona, FL
I have a CVD come apart on my kids creeper over the weekend. Called Venom, and he suggested I run double grub screws (2.5mm x 2.5mm) on all the CVD's and the driveshafts (if still stock). As you can use both sides to hold the pin.
01-19-2010, 11:48 AM | #10 |
Question...what pinion you guys run? I bought a Tekin FXr and the tekin Pro 45T. I beleive I would need ot run a little smaller pinion then stock correct?
01-19-2010, 12:15 PM | #11 |
Rock Crawler Join Date: Sep 2005 Location: Duncan, BC, Canada
I was running a Novak rooster crawler, HPI Saturn 35T, and the stock 15T pinion for a while. Swapped to a 12T pinion recently and Now I'm prebably going to swap back to a 15T pinion to gain that teensy bit of wheel speed back. Probably be adding a cell to my battery pack soon as well.
01-20-2010, 09:49 AM | #12 |
01-21-2010, 06:17 PM | #13 |
thanks I will try out with a 14t. I bought a 12t-16t set form LHS just in case...
01-22-2010, 05:06 PM | #14 |
| progress...
I know everyone likes pictures so thought I would keep posting them up... I painted my creeper body a little simple. first time I have ever used liquid mask.. Candy Apple Red and Outlaw Black Pactra Spray Can I assembled lower links and attached to trans with stock skids... I am using taps for every part that screws into plastic....I read here that it helps and it certainly helps the wrist...I had to go to local micro tool company as LHS didnt have all the sizes but i got some real nice hardened drivers for real cheap..WIHA is the brand... |
01-22-2010, 05:09 PM | #15 |
Very nice job on your body Wiha makes really good tools, i've worked on machines for over 30 years I have an ass load.
01-22-2010, 05:10 PM | #16 |
| goodies
I almost forgot..some goodies arrived yesterday from CKRC CRawlers and RCBros.... HB Rovers, Tekin FXR +Pro 45T, CKRC Stage II Suspension kit, Venom locker servo kit, and couple other things CKRC only had blue links in stock so I cleaned those up..btw don't put EZ Off in crunched up aluminum foil...it apparently burns the foil and creates a very, very, very large smoke bomb....my neighborhood was covered in what may have been deadly gas for about an hour... polished with some mothers and a dremel..it was quite relaxing... |
01-22-2010, 05:15 PM | #17 |
RCC Addict Join Date: Oct 2008 Location: Plainfield, IL.
Damn son, your set! Have fun with it.
01-25-2010, 02:10 PM | #18 |
Since I had receiv3ed my stage II kit I decided I would try to complete as much as time permitted this weekend. Assembled tires with weight in front and none in rear. The LHS ran out of the screws I needed so i used stock sized screw in most locations on bead locks. I will change them out as needed. Also finished assembling front axle assembly with heat shrink over pins and good thread lock on set screws. Also assembled my shocks with stage II mods to them. I ran a 30wt oil I had on the shelf. |
01-25-2010, 02:15 PM | #19 |
Also decided to break in new motor...first time I have ever done the under water break in before. Very interesting. |
01-25-2010, 02:20 PM | #20 |
Newbie Join Date: Apr 2009 Location: Orange County
I see that Venom finally put part #'s on the bags... That would of been nice when I was building mine. I took some time and labeled them myself before my build. Looks great man keep the pics coming! |
