![]() | #1 |
Keep Crawling in Crawling Join Date: Jan 2009 Location: Commerce City
If a driver gets one front and one rear tire through a gate and then hits a gate to point out does that driver get the progress? I know if you take a gate penalty and get one front and one rear though or if you get all four tires through it is progress but was wondering on the other situation.
![]() | #2 |
I wanna be Dave Join Date: May 2005 Location: CITY of CHAMPIONS!!
depends on when progress and the gate was hit, if the judges calls progress then you hit the gate, then yes you will get progress, if you have not progressed the gate before hitting gate, you will not get progress. ex going through a gate at an angle and you get both front wheels through and the r rear passes through befor the left rear, your r rear can go through the gate and get progress and the l rear hits the gate. |
![]() | #3 |
MODERATOR™ ![]() Join Date: Jul 2004 Location: Ohio
| ![]() Happens all the time, and yep, Progress called, then gate. Specific order of events is important.
![]() | #4 |
dnf ![]() Join Date: Sep 2009 Location: Under a big fkn rock.
I'm probably wrong,but if hitting a gate will point you out. even if its your last rear tire that hits,no progresso I think. cuz you have to completely get through the gate to get progress. not just break the plane. if you hit a gate trying to get progress you have pointed yourself out befor clearing the gate. |
![]() | #5 |
![]() | #6 |
Rock Crawler Join Date: May 2008 Location: Cleveland, Ohio
we had that situation happen on gate 10 so if progress is called when the 1st rear tire is thru the gate, the clock stops and it wouldn't matter if he hit the last gate, right? |
![]() | #7 |
| ![]() As a judge do you supposed to call Progress when one front and one rear breaks the plane, then call a gate penalty if the driver does not progress all four tires?
![]() | #8 |
![]() | #9 |
![]() | #10 | |
| ![]() Quote:
in your example yes you hit the gate trying to get progress before clearing the gate so you point out no progress, if it isnt the last gate you can get progress and a gate penalty, that gate penalty will be tallied under the next gates penalties not the cleared/progressed gate. | |
